2FE2W -V2 Module Problem
rsjavahar
Level 3
Level 3
i recently we brought 3 2FE2W-V2 network modules. i have a tipical problem if i gave one ip address to once interface it will work if i give the same pool of IP address it will not work it is showing interface up Protocol UP but i packet loss . if i gave other pool of ip address it is working . or if i change the slot (i am using 3660 router 64DRAM/32Flash IOS c3640-i-mz.123-14.T6) then it is working but i don't have any problem with old cards. what could be the problem .
Please find the Output and config statements
cd-ajg#sh ip int brief
FastEthernet0/0 unassigned YES unset administratively down down
FastEthernet0/1 unassigned YES unset administratively down down
cd-ajg#conf t
Enter configuration commands, one per line. End with CNTL/Z.
cd-ajg(config)#int f0/0
cd-ajg(config-if)#ip add 192.168.1.190 255.255.255.0
cd-ajg(config-if)#no shut
cd-ajg(config-if)#^Z
cd-ajg#
*Mar 1 00:04:46.563: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Mar 1 00:04:47.107: %SYS-5-CONFIG_I: Configured from console by console
cd-ajg#
cd-ajg#
*Mar 1 00:04:56.623: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
cd-ajg#
cd-ajg#ping 192.168.1.41
Sending 5, 100-byte ICMP Echos to 192.168.1.41, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/4 ms
cd-ajg#conf t
cd-ajg(config)#int f0/1
cd-ajg(config-if)#no ip add
cd-ajg(config-if)#int f0/0
cd-ajg#
*Mar 1 00:05:56.723: %SYS-5-CONFIG_I: Configured from console by console
cd-ajg#conf t
cd-ajg#
cd-ajg#
*Mar 1 00:06:29.967: %SYS-5-CONFIG_I: Configured from console by consoleping
*Mar 1 00:06:30.563: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
cd-ajg#
Success rate is 0 percent (0/5)
cd-ajg#
globalnettech
Level 9
Level 9
assuming that 192.168.1.41 is a host, how is this host connected to the router (e.g. through a switch, trunk) ? Can you ping the host when you connect the host directly to the FE port(s) ?
GNT
hi
i am using cross over cable to connect router to my laptop (192.168.1.41), and i worked with switch too.. i am not working on any trunks.
