3 vlan in the same physical port
habouzyad
hello,
i want ask if there is possible to affect a port in the switch to the 3 vlans ( one vlan voice and two vlan data)?
tahnks
lee.reade
Level 4
Level 4
If you make the port trunk port, then it can carry up to 4096 vlans, if its an 802.1q trunk port.
Check out..
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/layer2.html
LR
Giuseppe Larosa
Yes,
you should use the following: (example)
int gix/y
switchport trunk enc dot1q
switchport mode trunk
switchport trunk allowed vlan 10,20,30
switchport voice vlan 10
Hope to help
Giuseppe
