3560 Baud rate
janesh_abey
Hi all,
I changed the baud rate for the console to 115200bps to speed up an IOS transfer through xmodem but cannot reset it back to the default 9600.Tried "set BAUD 9600" & "unset BAUD" seperately under switch: prompt but with no luck.Any help is much appreciated.
Giuseppe Larosa
try to reload it and to access it via telnet then modify the confreg in order to have again 9600 bps
or try to use confreg at rommon prompt.
It will make some questions and one of them is about console speed
see :
http://www.cisco.com/en/US/products/hw/switches/ps663/products_password_recovery09186a00800945f7.shtml
Hope to help
Giuseppe
Hi Qiusar,
Many thanks fore the feedback but confreg is not supported on 3560.Found the cause.basically the console baud was change to 115200 which was not changed back to defualts.unset BAUD at switch: defaulted the baud to 9600 but as there was a different setting on the startup, output was not readable.
cheers
Appelsapje
In our class we have 2 Cisco 3560 serie PoE.
They had diffrent baud rates. 9600 and 57600 for the same purpuse as you, to upload faster IOS.
you must first in rommon typ
set BAUD 9600   (baud must be in capital!!!)
:flash init
:boot
than after boot
line console 0
speed 9600
exit
write
reload
after reload
erase startup config
