3560 Clear port-asic stats
BRYAN HUNT
I am setting up QOS for SIP phones on a Cisco 3560.
I would like to set up individual ports for QOS, then test the results.
On this switch model, it appears that the command to view output queues for port 1 is: show platform port-asic stats enqueue gi 0/1
This seems to show the frames by queue and threshold.
Before I set QOS on the port and test, I would like to clear those statistics for port 1.  I have been unable to find any command that will clear those stats so I can start with a clean slate.
Can someone enlighten me on how to clear those stats?
Thanks.
Bryan Hunt
BRYAN HUNT
Some follow-up on this question:
- Apparently our model (and/or firmware) is a little dated.  In newer models, the standard:
show mls qos interface gigabitEthernet 1/0/1 statistics
does show the output/egress queue statistics at the end.  Our model/firmware does not.
So the
command is the only way to see them on our model.
There is no command to clear those stats, a reboot is the only way.
Thanks.
Bryan Hunt
