twisted cable colour pair (568a and 568b) -- does the colours matter ?
SJ K
Level 5
Level 5
Hi all,
I have understand the difference in the colours pairing between 568a and 568b.
Q1) As I can make a straight cable, using both 568a on both side, or 568b on both side. And even for crossover cable, as long as 1 head is 568a and another as 568b, it doesn't matter where head/direction is plug into the devices requiring crossover cables. (e.g. I can plug headA into device B or headB Into device B)
Hence can I check, does the colours in "GreenStrip/Green" 568a and "OrangeStripe/Orange" 568b has any significant differences in terms of usages ?
Q2) Can I know what are the blue and brown pairing use for ? As I know the green and orange are use for TX/RX and vice versa
Noob
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The cable color coding is really only to insure that you can identify the same cable wire on both ends.
Usage of specific color coding, for specific pins, is just a convention. That convention is likely to be found on the Internet, if you search for it.
Joseph W. Doherty
Disclaimer
Posting
