3560 IOS upgrade question
davinci
Cisco website says that I have a few options for IOS upgrade.  See screenshot.  Does this mean that IOS 12 and IOS 15 are both valid options for upgrade?
Here is my current IOS
switch#sh version
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:04 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
switch uptime is 6 weeks, 1 day, 21 hours, 15 minutes
System restarted at 16:50:42 CST Sat Nov 23 2019
System image file is "flash:c3560-ipservicesk9-mz.122-55.SE12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560G-24PS (PowerPC405) processor (revision L0) with 131072K bytes of memory.
Processor board ID FOC1541Z1MB
Last reset from power-on
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:08:30:F0:4D:80
Motherboard assembly number : 73-10213-07
Power supply part number : 341-0108-04
Motherboard serial number : FOC15364NMM
Power supply serial number : DCA1528A4JF
Model revision number : L0
Motherboard revision number : A0
Model number : WS-C3560G-24PS-E
System serial number : FOC1541Z1MB
Top Assembly Part Number : 800-27478-04
Top Assembly Revision Number : D0
Version ID : V08
CLEI Code Number : COMBB10BRA
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3560G-24PS 12.2(55)SE12 C3560-IPSERVICESK9-M
Configuration register is 0xF
The upgrade path allows you to jump between versions. Keep in mind that the v15 train has a quite significant microcode patch. This will be installed during first boot and will give the impression the switch has hung. Keep a console cable connected to monitor the output. It will take between 20-30 minutes.
cheers,
Seb.
12 Replies 12
Seb Rupik
Hi there,
Both 12.2(55)SE12 and 15.0(2)SE11 are valid options for your switch. Keep in mind that they are different software trains and will have slightly different software features available.
Thankfully they are released within two months of each other so will probably have the same security fixes, although at this age (2017) they will both have plenty of active vulnerabilities.
Check the release notes of both and confirm that any open caveats will not impact your existing configuration.
cheers,
Seb.
Thanks, will I be able to go from current 12.2(55)SE12 to 15.0(2)SE11?
My IOS upgrade is in response to CVE-2008-5161.
cheers,
Seb.
Will do, thanks and happy new year.
This is a "plain" 3560 (copper ports are non-GigabitEthernet), right?
If this is a plain 3560, then the "highest" version is 12.2(58)SE train.
This is due to the size of the flash.
NOTE:  Stick with 12.2(55)SE train because it is a very stable train.
Yes, it is copper ports only switch.
Are you sure about the flash space?  New image which I want is only 15 MB.
Current flash usage:
switch#dir
Directory of flash:/
4 -rwx 976 Feb 28 1993 18:01:19 -06:00 vlan.dat
5 -rwx 12745998 Jun 29 2018 05:49:50 -05:00 c3560-ipservicesk9-mz.122-55.SE12.bin
6 -rwx 10776 Jan 6 2020 12:01:02 -06:00 config.text
7 -rwx 4120 Jan 6 2020 12:01:02 -06:00 multiple-fs
8 -rwx 9166 Apr 12 2017 23:12:55 -05:00 aldleg-x09_April12-2017.txt
9 -rwx 3843 Jan 6 2020 12:01:02 -06:00 private-config.text
32514048 bytes total (19736576 bytes free)
Plain 3560/3750 only has 32 mb flash while 3560G/E/X have 64 mb flash.
Read the Release Notes for the version you are looking for.  In the Release Notes for 15.0(2)SE, for example, it is explicitly stated:
Not all Catalyst 3750 and 3560 switches can run this release. These models are not supported in Cisco IOS Release 12.2(58)SE1 and later: WS-C3560-24TS, WS-C3560-24PS. WS-C3560-48PS, WS-C3560-48TS, WS-C3750-24PS, WS-C3750-24TS, WS-C3750-48PS, WS-C3750-48TS, WS-3750G-24T, WS-C3750G-12S, WS-C3750G-24TS, WS-C3750G-16TD. For ongoing maintenance rebuilds for these models, use Cisco IOS Release 12.2(55)SE and later (SE1, SE2, and so on).
Hope this helps.
i´ve update my ios, baut after all process i can not manage my switch. He´s stuck after that information: Switch Ports
* 1 26       WS-C3560-24PS 12.2(55)SE12 C3560-IPSERVICESK9-M
_
If your switch cannot move forward, you'd better upload a suitable image with recovery mode [mode button, flash_init, copy and boot].
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swtrbl.html#wp1452100
I don't know if you are interested in switching to v15, but I 've been using the fanless 3560/12/PCS with 15.0(2)SE11 (IPSERVICESK9) for 3 years with no issues at all.
Plain 3560 switches (excluding the 3650-12P) only has 32 mb flash.
15.0(2)SE train requires 64 mb flash.
The "highest" train the plain 3560 switches can go is 12.2(55)SE train.
As stated in the Release Notes itself:
Not so:
Cisco3560#show ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 15.0(2)SE11, RELEASE SOFTWARE (fc3)
Compiled Sat 19-Aug-17 09:21 by prod_rel_team
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1)
Cisco3560 uptime is 23 minutes
System restarted at 16:11:07 UTC Wed Nov 11 2020
System image file is "flash:c3560-ipservicesk9-mz.150-2.SE11/c3560-ipservicesk9-mz.150-2.SE11.bin"
cisco WS-C3560-8PC (PowerPC405) processor (revision A0) with 131072K bytes of memory.
1 Virtual Ethernet interface
8 FastEthernet interfaces
1 Gigabit Ethernet interface
Model revision number : A0
Motherboard revision number : B0
Model number : WS-C3560-8PC-S
Hardware Board Revision Number : 0x01
* 1 9 WS-C3560-8PC 15.0(2)SE11 C3560-IPSERVICESK9-M
Cisco3560#show flash
2 -rwx 3838 Nov 11 2020 16:21:01 +00:00 config.text
3 -rwx 2945 Oct 2 2007 02:27:55 +01:00 config.text.renamed
4 -rwx 1492 Nov 11 2020 16:21:01 +00:00 private-config.text
5 -rwx 5 Oct 2 2007 02:27:55 +01:00 private-config.text.renamed
6 drwx 512 Nov 11 2020 15:20:49 +00:00 c3560-ipservicesk9-mz.150-2.SE11
525 -rwx 616 Mar 1 1993 00:05:45 +00:00 vlan.dat
526 -rwx 2072 Nov 11 2020 16:21:01 +00:00 multiple-fs
27998208 bytes total (5704704 bytes free)
itdAbbas
I just formatted the flash and now I am having difficulties getting the image file. (ios).
Can anyone help in this regard and how to get the ios?
