Difference between WS-C3560X-48P-L and WS-C3560X-48PF-L?
Gregor Blaj
I've been looking through the Cisco documentation but I cannot find what the difference is between a model with a PF in a name vs just P? I know both are PoE. Possibly more power is available for the 'F' models?
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-x-series-switches/data_sheet_c78-584733.html
Gregor
Bilal Nawaz
Hello Gregor,
I believe you are correct. Different power supply, Please see here:
http://www.cisco.com/c/en/us/products/switches/catalyst-3560-x-series-switches/models-comparison.html
and also listed in the data sheet, table 6.
Hope this helps.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
Hello Gregor,
Hope this helps.
I see, thanks for that. Suppose I need to figure out the PoE requirements in that case :)
itdAbbas
Can you use the same iOS for either one of the switches and inter use it?
