3560 IP Base vs 3750 Stackable
Anthony Filice
Community Member
I have read many sheets on the 3560, we currently use them. We do have a situation where we need Fault-Tolerance built into our environment. I have looked into the cluster feature of the 3560 but it would seem that is for management only. I see the 3750's are stackable and that is the main advantage over the 3560's. Does anyone know if it is possible to 'stack' the 3560's in a similar fashion? I dont want to scale these down to Layer 2 because we are using the IP Base features. Any ideas on this? Does anyone have pair of 3560's running A/P?
Anthony Filice
Community Member
It would appear as if this is not possible as I have read through countless tech spec's.
Reza Sharifi
Unfortunately, the 3560 series switches are not stackable, and that is actually the only difference between the 3560 series and the 3750.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As Reza noted, the 3560 can not be stacked.  For redundancy you would either need to do "traditional" L2 loops, and use a STP to control them, or you might use FlexLinks.
BTW, for original 3560s there's a "special" 50CM "stack" cable.  Basically, it's a less expensive way to use gig SFP ports between 3560s.
