Cisco 6509 Sup2 to Sup32 upgrade
littlespace
I need to upgrade 2xsup2 module to 2xsup32 on my cisco 6509. I just found out that I can not have the CISCO WS-X6500-SFM(Cisco Switch Fabric Module switch) with Sup32 and I have to remove 2 xCISCO WS-X6500-SFM2 modules from the switch.I am using this switch as a access switch and most of the ports are 100Mbps.
Could you please let me know if the upgrade would be safe or not as far as the bandwitdh?
Mike
Reza Sharifi
What is the model number for the 100Mbps blade you are currently using?
From Sup-32 Q&A
Q. Which line cards are supported by Sup32?
A. All classic line cards and all CEF256 line cards (without a Distributed Forwarding Card [DFC]) are supported at FCS.
Q. Which line cards are not supported by Sup32?
A. The following series of line cards are not supported by Sup32: WS-X67XX, WS-X68XX, SFM, and DFC-based cards.
