3560 mls qos - output queues counters?
antong001
Hi!
I have WS-C3560G-24TS     15.0(2)SE4.
In gi0/10 we received IPTV multicast traffic only.
interface GigabitEthernet0/10
description IPTV
switchport access vlan 929
switchport mode access
switchport nonegotiate
mls qos trust dscp
channel-protocol lacp
channel-group 3 mode active
service-policy input iptv-cos
end
on port input - 350mbit - output 2000 Bit/s!
Queueing strategy: fifo
  5 minute input rate 348797000 bits/sec, 32008 packets/sec
Then i send command:
clear counters
clear mlq qos int stat
and
sh mls qos int gi0/10 st
after 5-10 seconds i see:
GigabitEthernet0/10 (All statistics are in packets)
  dscp: incoming
  0 -  4 :      156657            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :           4            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :      156661            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :           4            0            0            0            0
  5 -  7 :           0            0            0
  output queues enqueued:
queue:    threshold1   threshold2   threshold3
queue 0:           0           0           0
queue 1:           4           0           0
queue 2:           0           0           0
queue 3:           0           0      112066
  output queues dropped:
queue 0:           0           0           0
queue 1:           0           0           0
queue 2:           0           0           0
queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
Question!
Why i have 112066 packets in output queue 3, then bitrate output - 5 minute output rate 0 bits/sec, 0 packets/sec  and 7 packets output, 576 bytes after clear.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I believe the enqueued counter count total number of time packets needed to be enqueued, not current queue depth.
Although your average egress rate is very low, it's possible some kind of microburst happens from time to time that enqueues some packets.
If this is happening, the small burst doesn't overflow your queue as you stats don't show any drops.
I have any time this bitrate.
a few hours later I see:
bm18.lan#sh mls q int gi0/10 st
  dscp: incoming
  0 -  4 :   849303034            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0         3517            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :       45265            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :   849324148            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  5 -  7 :           0            0            0
queue 0:           0           0           0
queue 1:       45265           0        4071
queue 2:           0           0           0
queue 3:           0           0  605666519
queue 0:           0           0           0
queue 1:           0           0           0
queue 2:           0           0           0
queue 3:           0           0           0
send:
  dscp: incoming
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  5 -  7 :           0            0            0
  cos: outgoing
  5 -  7 :           0            0            0
queue 0:           0           0           0
queue 2:           0           0           0
queue 0:           0           0           0
queue 1:           0           0           0
queue 2:           0           0           0
queue 3:           0           0           0
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#clear mls qos int st
bm18.lan#
bm18.lan#
bm18.lan#clear counters
Clear "show interface" counters on all interfaces [confirm]
bm18.lan#
bm18.lan#
bm18.lan#
bm18.lan#sh mls qos int gi0/10 st
  dscp: incoming
  0 -  4 :     1141981            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            3            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :          92            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :     1142010            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :          92            0            0            0            0
  5 -  7 :           0            0            0
queue 0:           0           0           0
queue 1:          92           0           5
queue 2:           0           0           0
queue 3:           0           0      810894
queue 0:           0           0           0
queue 1:           0           0           0
queue 2:           0           0           0
queue 3:           0           0           0
bm18.lan#
bm18.lan#
bm18.lan#sh int gi0/10
GigabitEthernet0/10 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0019.e7b1.c68a (bia 0019.e7b1.c68a)
  Description: IPTV
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 89/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:07, output 00:00:06, output hang never
  Last clearing of "show interface" counters 00:00:37
  Output queue: 0/40 (size/max)
  5 minute input rate 351051000 bits/sec, 32219 packets/sec
     1202212 packets input, 1637377057 bytes, 0 no buffer
     Received 1202205 broadcasts (1202205 multicasts)
     0 watchdog, 1202205 multicast, 0 pause input
    83 packets output, 6682 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
bm18.lan#
bm18.lan#
Queue counter is reset to 0, and after 10-15 seconds I see 810,894 packets, although a sh Int gi0/10 I see only 83 outgoing packet!
http://s019.radikal.ru/i636/1311/b4/d5ec7bcd853e.png
Disclaimer
Posting
Well then, perhaps you're bumping into a bug.
