3560 not passing large packets across trunk port
nohare
Hi all, I have a strange problem:
I have a 3560 with 8 VLANs configured. Each VLAN has a Layer 3 (IP) interface configured. On 4 of the 24-ports in the switch I have them configured to support a voice and data vlan (dot1q trunked) as I have Mitel 5224 IP phones plugged into the these ports. Users of these 4 phones have there data connection via the switch on the Mitel phone. The phones all work fine, register, get an ip and are in the correct VLAN. The PCs connected to them do get a DHCP address from the data VLAN but after testing cannot send pings or connect to many TCP services that use packets larger than 1468.
Here is the IOS port configuration for one of these 4 ports that are causing the problem:
interface GigabitEthernet0/10
switchport trunk native vlan 6
switchport mode trunk
switchport voice vlan 100
spanning-tree portfast
Here is my Layer3 VLAN config for VLAN 6 (DATA):
interface Vlan6
ip address 10.6.0.1 255.255.0.0
ip helper-address 10.1.1.251
ip dhcp relay information trusted
As a test, if I configured one of these ports in access mode, then I all data, large of small, TCP or ICMP and routing between other VLANs on the 3560 all works fine, as soon as I configure it is a trunk port, then the problem comes!!
VLAN 1 - 6 are for data, VLAN 100 is voice
Any ideas?
lgijssel
Level 9
Level 9
Are these the only ports with Mittel phones?
In that case, you should try what happens when you connect a PC directly, perhaps it is the IP phone that is causing this.
Leo
Pls increase your switch's system mtu to support jumbo frames.
system mtu 9000
regards
vanesh k
I have been doing some more testing and I have now discovered that large packet transmission was something to do with dot1q tagging of the native vlan. I thought this was disabled but wasn'.
I used the command "no vlan dot1q tag native" and this has fixed this issue!!
