3560 Port Configuration
jdavid6568
Does anyone know how to configure a 3560 switch port that is connecting to an ESX host with multiple VM's.    ?????
wilrow113
If you are using the same subnet on the vm's you just set the port up as access port on the vlan you want
If you are using the esx with vlans then you needed to use the port in trunking mode
Hi Jason ,
If you have the VM Running with multiple servers of different subnets use  trunking on the switch port or else  you can use  as access port .
Angus
