3560 Question
CameronA
Community Member
Can a WS-C3560CX-12PD-S switch be configured to be a WS-C3560CX-PC-S switch??  I don't need the stack functions and I already have some of the PC versions.  I just want to simplify the system so I can access each switch GUI and setup to be the same.
This is hardcoded . You can change this.
Reza Sharifi
The difference is that WS-C3560CX-12PD-S comes with 2 10Gig uplinks versus the WS-C3560CX-12PC-S comes only with 2 1Gig uplinks. Other than this, there is no difference, and you should be able to connect to both switches the same way.
See table-10 in this link:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-cx-series-switches/datasheet-c78-733229.html
