3560's not routing...
ricschaaf
Can anyone please tell me why these two 3560's are not routing?
Test#sh run
Building configuration...
Current configuration : 2605 bytes
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/17
no switchport
ip address 192.168.1.1 255.255.255.252
interface Vlan1
ip address 10.90.153.1 255.255.255.0
router eigrp 1
network 10.90.153.0 0.0.0.255
network 192.168.1.0 0.0.0.3
auto-summary
ip default-gateway 10.90.153.200
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/17
E3#sh run
Current configuration : 2816 bytes
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
no switchport
ip address 192.168.1.2 255.255.255.252
interface GigabitEthernet0/48
switchport mode trunk
duplex full
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
interface Vlan1
ip address 172.23.31.34 255.255.255.224
router eigrp 1
network 172.23.31.32 0.0.0.31
auto-summary
ip default-gateway 172.23.31.33
ip classless
ip route 0.0.0.0 0.0.0.0 172.23.31.33
16 Replies 16
Actually, yes. Once upon a time I did config one
of the ports on E3 with an address from the
10.90.153.0/24 net. It has been long removed.
Why would that cause a problem? Does something
remain in the system?
Here's the latest from E3:
E3#sh run
Current configuration : 3191 bytes
version 12.2
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
no switchport
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
duplex full
auto qos voip trust
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
interface GigabitEthernet0/52
interface Vlan1
interface Vlan192
no ip address
router eigrp 1
no auto-summary
ip classless
Configure the command 'no ip split-horizon eigrp 1' under g0/17 int on Test router. Then clear the eigrp neighbor and routes and see if that helps.
Sundar
