3560 SFP Fiber Test
hufa97
Is there a simple way to test the fiber ports?
Reza Sharifi
Antonio,
If you have another switch or router, use an SC to SC patch cord or whatever fiber type you need and connect them back-to-back and see if the interface comes up.
If you don't have any other switch or router with fiber port, get a fiber to copper media converter and connect it to your PC.
Reza
Reza Sharifi
Antonio,
Reza
Thanks Reza.
