Enable traceroute after blocking ICMP
David Lin
I am trying to disable PING and Tracerout but leave it enable for internal hosts.
After done below configuraion, I can ping any outside hosts but can't do traceroute.
Can anyone tell me what configuration is missing? Thank you.
ip access-list extended ICMP
permit icmp any any echo-reply
permit icmp any any traceroute
deny icmp any any
permit ip any any
interface GigabitEthernet1/1
ip access-group ICMP in
Lucien Avramov
Level 10
Level 10
Traceroute can be used over different protocols and port. It does not have to be over icmp.
Different vendors / OS use different implementation for traceroute.
So my configuration is correct?
Thank you.
Your config seems right.
You need to find what type of traceroute your computer is using and then you can allow this on the router.
It sounds like your computer is not using ICMP based traceroute.
I assume this ACL is applied inbound at the edge?
I would suggest adding
permit icmp any any ttl-exceed
permit icmp any any port-unreachable
John
