3560C Amber LED but no error
dcuddefo
I have a PS3 connected to a Gig port on my 3560. When I boot-up the PS3 I have to wait around 30 seconds for it to get DHCP.
I noticed the orange LED would stay on and go green after 30 seconds. I assumed I would have an error-state but I do not, the port show connected with no errors even though it's orange. I have no connectivity from the ps3 until the light goes green and then all is well. The port is access and I have manually configured duplex and speed.
Switch>show version
Cisco IOS Software, C3560C Software (C3560c405ex-UNIVERSALK9-M), Version 12.2(55)EX3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 10-Aug-11 08:10 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560C boot loader
BOOTLDR: C3560C Boot Loader (C3560C-HBOOT-M) Version 12.2(55r)EX1, RELEASE SOFTWARE (fc1)
Switch uptime is 5 days, 6 hours, 52 minutes
System image file is "flash:/c3560c405ex-universalk9-mz.122-55.EX3.bin"
pille1234
Level 3
Level 3
Configure 'spanning-tree portfast' where you entered speed and duplex and the 30s waiting period goes away.
5 Replies 5
Reza Sharifi
Can you post the config for the port connected to PS3?
pille1234
Level 3
Level 3
yay - of course!
It's odd how ios doesn't give any error other than the orange led. But thanks so much. 30 seconds quicker bootup time
When you enable portfast, the port transition to forwarding state immediately without going through listening and learning STP phases.
