09-22-2009 05:38 AM - edited 03-06-2019 07:50 AM
Hi!
Thinking of 3560E switches with 2 X2 10G uplinks, I was wondering if I can use, at the same time, 1 uplink port @ 10G and the other one @ 1G, with the proper CVR-X2-SFP converter and SFP modules.
Thanks in advance!
Martin.
09-22-2009 07:25 AM
Believe if you use a TwinGig converter in one of the module slots, you can connect one or two gig SFP links to it while the other module slot is 10 gig.
09-22-2009 05:07 PM
3560E-12D support TwinGig Adapter Converting 10 Gigabit Ethernet X2 Interface into Two Gigabit Ethernet SFP Interfaces.
