Upgrdea Cisco871-K9
maucapina
Hi Friends
I have a Cisco871-K9 router with Advanced Security IOS software, but I need to do a IOS Advanced IP Services upgrade, however it's also necessary, to make an update to the flash memory
is it possible to upgrade memory on this device?
Thanks for your help!!!
Marcelo
Lucien Avramov
Level 10
Level 10
You can not upgrade the flash memory on this device. If you open the device you break the warranty on it.
Leo Laohoo
Hi Marcelo,
You can purchase additional DRAM or Strata Flash module for upgrades.
That is correct, disregard my previous post, +5 for this.
Here is what you need to order:
https://www.cisco.com/en/US/docs/routers/access/800/hardware/notes/800upgrd.html
Thanks Lucien.
