3560X Output drops to ASA 5505
conleya
I have a 3560X that is directly connected to an ASA 5505.  I am seeing output drops on the 3560X interface that connects to the ASA.  Below are the troubleshooting commands I have ran, but I don't see any indication to what is causing the problem.
3560X
show run int gig 0/24
interface GigabitEthernet0/24
description To SJ-ASA-5505-A
no switchport
ip address 172.17.5.129 255.255.255.248
load-interval 30
end
show int gig 0/24
GigabitEthernet0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 44d3.ca2d.e041 (bia 44d3.ca2d.e041)
  Description: To SJ-ASA-5505-A
  Internet address is 172.17.5.129/29
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 78/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:17:21
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 52219
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 1030000 bits/sec, 1421 packets/sec
  30 second output rate 30784000 bits/sec, 3100 packets/sec
     1357921 packets input, 125902224 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     2921490 packets output, 3618171270 bytes, 0 underruns
show controllers gig 0/24 utilization
Receive Bandwidth Percentage Utilization   : 1
Transmit Bandwidth Percentage Utilization  : 28
ASA 5505
show run int eth0/1
interface Ethernet0/1
show int eth0/1
Interface Ethernet0/1 "", is up, line protocol is up
  Hardware is 88E6095, BW 100 Mbps, DLY 100 usec
        Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
        Available but not configured via nameif
        MAC address 0022.9051.d810, MTU not set
        IP address unassigned
        3666626874 packets input, 3792120130920 bytes, 0 no buffer
        Received 2 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        85899377236 switch ingress policy drops
        2593273425 packets output, 1186781461235 bytes, 0 underruns
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops
        0 rate limit drops
        0 switch egress policy drops
show run int vlan 1
interface Vlan1
nameif inside
security-level 100
ip address 172.17.5.130 255.255.255.248
show int vlan 1
Interface Vlan1 "inside", is up, line protocol is up
  Hardware is EtherSVI, BW 100 Mbps, DLY 100 usec
        MAC address 0022.9051.d817, MTU 1500
        IP address 172.17.5.130, subnet mask 255.255.255.248
  Traffic Statistics for "inside":
        3664712280 packets input, 3723344791180 bytes
        2593350130 packets output, 1131025416517 bytes
        58887 packets dropped
      1 minute input rate 2744 pkts/sec,  3353520 bytes/sec
      1 minute output rate 1263 pkts/sec,  88577 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 2792 pkts/sec,  3410504 bytes/sec
      5 minute output rate 1293 pkts/sec,  90418 bytes/sec
      5 minute drop rate, 0 pkts/sec
conleya
One other command I forgot to include:
show controllers ethernet-controller gig 0/24
     Transmit GigabitEthernet0/24             Receive
    772480356 Bytes                       1409426285 Bytes
   3666853963 Unicast frames              2593687278 Unicast frames
       667819 Multicast frames                     0 Multicast frames
            5 Broadcast frames                   252 Broadcast frames
            0 Too old frames              1409409901 Unicast bytes
            0 Deferred frames                      0 Multicast bytes
            0 MTU exceeded frames              16384 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames          1511474087 Minimum size frames
            0 8 collision frames           164532116 65 to 127 byte frames
            0 9 collision frames            51640320 128 to 255 byte frames
            0 10 collision frames           34149205 256 to 511 byte frames
            0 11 collision frames           22188891 512 to 1023 byte frames
            0 12 collision frames          809702911 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
    465887844 64 byte frames                       0 Valid frames, too small
     91340355 127 byte frames
     52102661 255 byte frames                      0 Too old frames
     72662816 511 byte frames                      0 Valid oversize frames
     61319517 1023 byte frames                     0 System FCS error frames
   2924208594 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
