3560x switch and boot system command
mguzman4158
I have a 3560x-24-t-s switch running c3560e-universalk9-mz.150-2.SE3.bin - This might be a silly question, but if I put the "boot system
flash:c3560e-universalk9-mz.150-2.SE3.bin" command it doesn't appear on the running or startup config between the boot-start-marker and boot-end-marker???? if I do show boot, it does show the correct path.. is just driving me crazy why it doesn't show on the configuration...any ideas?
hostname MYROUTER
boot-start-marker
boot-end-marker
MYROUTER#sh boot
BOOT path-list      : flash:c3560e-universalk9-mz.150-2.SE3.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
Allow Dev Key         : yes
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
NVRAM/Config file
      buffer size:   524288
Timeout for Config
          Download:    0 seconds
Config Download
       via DHCP:       disabled (next boot: disabled)
I try it on a gns3 router that I have and it does show the path between boot-start and boot-end, I wonder if is a IOS bug????
boot-start-marker
boot system flash:ios.bin
boot-end-marker
Cheers!!!
M
2 Accepted Solutions
Reza Sharifi
On smaller switch models, that is the correct behavior.  You can only have one boot statement and when you do "sh run" it will not show it, as that is default, but as you already know when you do a "sh boot" you see the correct image.
So, if you add a second boot statement, it will replace the first one.
Leo Laohoo
Please, oh please, DO NOT USE IOS version 15.0(2)SE3.
Cisco has already pulled all download links to this very specific version for all appliances.  Stick to either 12.2(55)SE7 or 15.0(2)SE2.
7 Replies 7
Reza Sharifi
That's not a bug.  This behaviour is evident in all Cat 2K and 3K switches.
Leo Laohoo
Thank you of all you for your replies and the FYI on this IOS I was not aware of.  I wish I could rated it all of you.  Thanks again!!!
You can rate all of our posts, if you want.  There's no limitation how many posts (other than yours) you can rate.  You just can't rate the same post more than once.
12.2(55)SE8 and 15.0(2)SE4 are now ready for download.
InayathUlla Sharieff
I agree with Leo that kindly downgrade your firmware first.
There is quite huge discussion going on this release which you are running on your switch.
https://supportforums.cisco.com/message/3969727#3969727
regards
Inayath
