Debug netdr on Cisco 4500
YUEN WAI NAM
Cisco 6500 / 7600 support debug netdr, does Cisco 4500 also support this feature ?
3 Accepted Solutions
Can you please try clearing the mac address table and update me the result.
I will give a explanation for that later if you want after getting to know the status .
Inayath
Yuen,
1)   the high cpu was due to SA Miss
SA Miss is populated when the source MAC is unknown for the packet so it is
sent to the CPU for mac learning.SA Miss generally is due to extensive mac
tcam being utilized utilized. But in our case the MAT was hardly utilized.
Did not observe any mac-flap . No STP changes was observed.
2)  along with SA miss we also see a lot of and "Vs Tunnel Data Pkt"
continuously incrementing
{Vs Tunnel Data Pkt          1913749950     15569     16162     13467      12827}
3)  After decoding the above packets the original packets were ASIC Sa Miss
packets on the standby which were tunneled from standby to active as Vs
Tunnel Data Pkt. This is the reason we were observing the "Vs Tunnel Data
Pkt" increment. The ASIC Sa Miss on the standby would cause SA-Miss on the
active.
When we say asic SA-Miss we mean that the src mac is not present in the hw
mac address table on the standby. The same mac address is present in the
software as well as hardware on the active.
The reason why we were seeing high cpu on the active sup was the fact that
the platform programming on active and standby (at least, at the single
point-in-time it was captured) that the original source MAC addresses on the
packets being tunneled to the VSS active are seen in the HW programming on
the active but not standby.  This is a potential cause for a persistent
learning state, which would be remedied by a dynamic MAC table clear
(assuming the problem didn't immediate occur again).
4) In our case we did not get the chance to clear the mac table as the cpu
dropped down and the issue got cleared on its own before we checked anything
further on the standby.
Inayath
*Plz rate all usefull posts and mark this thread as answered so that others may get benefited.
Yuen,
Glad to hear that. Please continue to work with TAC for the other issue.
Hope I have answered your query. Could I reuqest you to mark the thread as solved if no further questions are there.
Thanks in advance.
Inayath
16 Replies 16
InayathUlla Sharieff
Hi Yuen,
NO netdr is not supported on 4500.
Following are the debugs used on 4500:
debug platform packet all receive buffer ( wait for 2-3 minutes)
- debug platform packet all count
Inayath
*Plz rate if this info is helpfull and mark the thread as answerd if solved.
Tks, let try it.
Yuen,
The said above debugs are used when you are seeing high cpu.
What exactly are you looking for?
If you happen to troubleshoot high cpu then pleas euse the below link:
http://www.cisco.com/en/US/customer/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
Inayath
#show platform cpu packet statistics all | in Miss
Sa Miss                              0         0         0         0          0
PVMapping Miss                       0         0         0         0          0
Sa Miss                     1813484461     12686     14616     11363       8665
PortVlanMap Miss Drop                    0         0         0         0          0
PV Mapping Miss                      0         0         0         0          0
Sa Miss                              0         0         0         0          0
Sa Miss                              0         0         0         0          0
ftnsw4501#show platform cpu packet statistics all | in Miss
Sa Miss                              0         0         0         0          0
Sa Miss                     1813553600     12686     14616     11400       8665
The switch high CPU with large no. of Sa Miss, the debug platform packet all receive buffer can help to capture those packets ?
Yuen,
Yes you can still capture the packets by debug.
Can you get me the output of following
show process cpu sorted | ex 0.00%
show platform cpu packet statistics << to check the queues on CPU ( Check the Q which has more pack utilization)
show platform cpuport (may not work as it's depricated)
Show platform health | ex 0.00 << which job consumes CPU
show spanning-tree summary
show spann det | in ieee|from|occur|is exec
show interface | include line|drops
Inayath
Yuen,
The SA Miss events are caused by software L2 host learning.
The hardware sends copies of packets to the CPU so we can learn their source MAC address locations.
These copies are then dropped.
This also indicates the mac address table is always being updated.
So we need to find out why mac address table is updated so frequently.
One way is enable mac notification:
MAC notification can be enabled the following, global config lines, using
the maximum buffer size:
mac address-table notification change
mac address-table notification mac-move
mac address-table notification change history-size 500
mac address-table notification change interval 10
configure this, wait 30 seconds or so (the switch may generate logging messages if there are MAC flaps),
then grab 'show mac address-table' and 'sh mac address-table notification
change' also 'sh log'
 After taking the captures,
disable mac address-table notification
Inayath
*********Please rate all usefull posts.
Hi Inayath,
I tried capture the mac move and change , nil output, anything I missed ?
#sh mac address-table notification change
MAC Notification Feature is Enabled on the switch
Interval between Notification Traps : 10 secs
Number of MAC Addresses Added : 0
Number of MAC Addresses Removed : 0
Number of Notifications sent to NMS : 0
Maximum Number of entries configured in History Table : 500
Current History Table Length : 0
MAC Notification Traps are Disabled
History Table contents
Yuen.
We have to look into this more. Provide me the following outputs:
show logs
Inayath
Hi Inayath,
sw4501#show process cpu sorted | ex 0.00%
Core 0: CPU utilization for five seconds: 14%; one minute: 14%;  five minutes: 15%
Core 1: CPU utilization for five seconds: 73%; one minute: 73%;  five minutes: 72%
PID    Runtime(ms) Invoked  uSecs  5Sec     1Min     5Min     TTY   Process
8509   1812354     12916291 200    43.84    43.88    44.07    0     iosd
11862  2106641     19183442 55     0.12     0.09     0.08     0     ffm
11268  932135      36823769 141    0.08     0.04     0.04     0     cpumemd
6068   1358675     18936146 7      0.04     0.01     0.04     0     pdsd
1      995         872      1141   0.00     0.00     0.00     0     init
2      0           85       11     0.00     0.00     0.00     0     kthreadd
3      2760        439566   6      0.00     0.00     0.00     0     migration/0
4      103         16762    6      0.00     0.00     0.00     0     ksoftirqd/0
5      2595        417566   6      0.00     0.00     0.00     0     migration/1
6      271         47120    5      0.00     0.00     0.00     0     ksoftirqd/1
7      204208      11270310 18     0.00     0.00     0.00     0     events/0
8      267800      11445837 23     0.00     0.00     0.00     0     events/1
9      6           688      9      0.00     0.00     0.00     0     khelper
64     4252        16133    263    0.00     0.00     0.00     0     kblockd/0
65     3329        13109    253    0.00     0.00     0.00     0     kblockd/1
78     0           21       1      0.00     0.00     0.00     0     khubd
81     0           23       0      0.00     0.00     0.00     0     kseriod
86     7           25       282    0.00     0.00     0.00     0     kmmcd
126    18523       1488901  12     0.00     0.00     0.00     0     pdflush
127    0           40       4      0.00     0.00     0.00     0     pdflush
128    0           29       0      0.00     0.00     0.00     0     kswapd0
129    0           31       0      0.00     0.00     0.00     0     aio/0
130    0           33       0      0.00     0.00     0.00     0     aio/1
282    0           35       0      0.00     0.00     0.00     0     kpsmoused
296    0           37       0      0.00     0.00     0.00     0     edac-poller
315    0           39       0      0.00     0.00     0.00     0     rpciod/0
316    0           41       0      0.00     0.00     0.00     0     rpciod/1
360    80          442      182    0.00     0.00     0.00     0     udevd
620    135         3973     34     0.00     0.00     0.00     0     loop1
636    0           58       1      0.00     0.00     0.00     0     loop2
652    222         5957     37     0.00     0.00     0.00     0     loop3
2414   87          654      134    0.00     0.00     0.00     0     dbus-daemon
2986   4           422      10     0.00     0.00     0.00     0     syslog_format.s
2987   4           421      9      0.00     0.00     0.00     0     syslog_format.s
2988   3           420      8      0.00     0.00     0.00     0     syslog_format.s
2989   3           421      9      0.00     0.00     0.00     0     syslog_format.s
2993   7136        248528   28     0.00     0.00     0.00     0     syslogd
2997   5           458      12     0.00     0.00     0.00     0     klogd
3009   0           418      2      0.00     0.00     0.00     0     portmap
3054   1           433      2      0.00     0.00     0.00     0     sshd
3068   3           446      8      0.00     0.00     0.00     0     xinetd
3072   1           431      3      0.00     0.00     0.00     0     xinetd
4754   0           75       0      0.00     0.00     0.00     0     vsi work/0
4755   0           77       0      0.00     0.00     0.00     0     vsi work/1
4915   1726926     30735814 56     0.00     0.01     0.00     0     pdsvslifshim
4921   74134       7443541  9      0.00     0.00     0.00     0     watchdog
5541   55          1589     35     0.00     0.00     0.00     0     cat4k-epc_sm_li
5722   926         35619    26     0.00     0.00     0.00     0     slproc
5922   858557      36622867 23     0.00     0.00     0.02     0     ha_mgr
5928   292969      29382331 9      0.00     0.00     0.00     0     oscore_p
5936   102         795      128    0.00     0.00     0.00     0     btrace_rotate.s
5940   450006      40550520 11     0.00     0.00     0.00     0     platformmgr
5946   289564      29385597 9      0.00     0.00     0.02     0     sysmgr
5950   289425      29382491 9      0.00     0.02     0.03     0     profiled
5956   291158      29384208 9      0.00     0.00     0.00     0     os_info_p
5960   295279      29416979 10     0.00     0.01     0.00     0     eicored
5966   501384      33114372 15     0.00     0.00     0.02     0     plogd
6020   292069      29382612 9      0.00     0.01     0.03     0     ns_oir_proxy
6088   290448      29385071 9      0.00     0.00     0.00     0     iifd
8095   294452      29394057 10     0.00     0.00     0.02     0     dtmgr
8129   1           1304684  0      0.00     0.00     0.00     0     sleep
8296   1           796      2      0.00     0.00     0.00     0     inotifywait
8311   292898      94520288 3      0.00     0.00     0.00     0     snmp_subagent
8354   293820      29387329 9      0.00     0.00     0.02     0     cli_agent
8381   392462      36824718 10     0.00     0.00     0.03     0     ngdumper_provid
8982   292352      29394944 9      0.00     0.01     0.00     0     installer
9095   48          816      59     0.00     0.00     0.00     0     rollback_timer.
9209   1245860     45099407 27     0.00     0.01     0.03     0     mgmte_tap
9452   2           817      2      0.00     0.00     0.00     0     inotifywait
10385  291003      29382668 9      0.00     0.00     0.02     0     netd
10698  601839      29536277 20     0.00     0.04     0.01     0     licensed
11001  457870      36825989 12     0.00     0.01     0.03     0     liin_tap
11266  888985      1304683  681    0.00     0.04     0.01     0     oom_poll.sh
11273  307081      30141920 10     0.00     0.01     0.03     0     licenseagentd
sw4501#  show platform cpu packet statistics all
Executing the command on VSS member switch role = VSS Active, id = 2
Packets Dropped In Hardware By CPU Subport (txQueueNotAvail)
CPU Subport  TxQueue 0       TxQueue 1       TxQueue 2       TxQueue 3
           0               0               0               0               0
           1               0               0               0               0
           2               0               0               0               0
           3               0               0               0               0
           4               0               0               0               0
           5               0               0               0               0
           6               0               0               0               0
           7               0               0               0               0
CPU Subport  TxQueue 4       TxQueue 5       TxQueue 6       TxQueue 7
           0               0               0               0               0
           1               0               0               0               0
           2               0               0               0               0
           3               0               0               0               0
           4               0               0               0               0
           5               0               0               0               0
           6               0               0               0               0
           7               0               0               0               0
RkGenericPacketMan:
Packet allocation failures: 0
Packet Buffer(SW Common) allocation failures: 0
Packet Buffer(SW ESMP) allocation failures: 0
Packet Buffer(SW EOBC) allocation failures: 0
Packet Buffer(SW SupToSup) allocation failures: 0
Packets Enqueued Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
                   0         0         0         0          0
Packets Not Enqueued Overall
                   0         0         0         0          0
Packets Dropped In Processing Overall
          1940527927     16037     16493     13774      13102
Packets Not Enqueued by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Unknown                              0         0         0         0          0
Sa Miss                              0         0         0         0          0
Nfe                                  0         0         0         0          0
CTS                                  0         0         0         0          0
MTU Check Fail                       0         0         0         0          0
ESMP                                 0         0         0         0          0
L2 Control                           0         0         0         0          0
Medianet Monitor                     0         0         0         0          0
Medianet Msp                         0         0         0         0          0
Export Fnf VSS packet                    0         0         0         0          0
Adj Same If                          0         0         0         0          0
Non Arpa                             0         0         0         0          0
Expired Ttl                          0         0         0         0          0
Ip Option                            0         0         0         0          0
Input If Fail                        0         0         0         0          0
Ucast Rpf Fail                       0         0         0         0          0
SrcIdx Check Fail                    0         0         0         0          0
Ipv6 Scope Fail                      0         0         0         0          0
L2 Bridge                            0         0         0         0          0
Rsvp                                 0         0         0         0          0
Rtp                                  0         0         0         0          0
L2 Router                            0         0         0         0          0
L3 Glean                             0         0         0         0          0
L3 Forward                           0         0         0         0          0
L3 Receive                           0         0         0         0          0
Input Acl Fwd                        0         0         0         0          0
Input ACl Copy                       0         0         0         0          0
Input Acl Punt                       0         0         0         0          0
Input Acl EPC Copy                    0         0         0         0          0
Input Acl BFD                        0         0         0         0          0
VSLP                                 0         0         0         0          0
VS Mgmt                              0         0         0         0          0
Vs Tunnel Control                    0         0         0         0          0
Vs Tunnel Data                       0         0         0         0          0
Output Acl Fwd                       0         0         0         0          0
Output Acl Copy                      0         0         0         0          0
Output Acl Punt                      0         0         0         0          0
Output Acl EPC Copy                    0         0         0         0          0
Output Acl 1ToN Port Sample                    0         0         0         0          0
Output Acl 1ToN Vlan Sample                    0         0         0         0          0
Output Acl 1To1 Sample                    0         0         0         0          0
Sw Packet w/ TxInfo                    0         0         0         0          0
Sw Packet for Bridge                    0         0         0         0          0
Sw Cpu Span                          0         0         0         0          0
Sw Not Active                        0         0         0         0          0
Packets Dropped In Processing by CPU event
Unknown                              0         0         0         0          0
Sa Miss                     1940521691     16037     16493     13774      13102
Nfe                                  0         0         0         0          0
CTS                                  0         0         0         0          0
ESMP                                 0         0         0         0          0
Non Arpa                             0         0         0         0          0
Ip Option                            0         0         0         0          0
L2 Bridge                            0         0         0         0          0
Rsvp                                 0         0         0         0          0
Rtp                                  0         0         0         0          0
L2 Router                            0         0         0         0          0
L3 Glean                             0         0         0         0          0
VSLP                                 0         0         0         0          0
VS Mgmt                              0         0         0         0          0
Vs Tunnel Control                 6230         0         0         0          0
Sw Packet w/ TxInfo                    6         0         0         0          0
Packets Not Enqueued by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Unknown                              0         0         0         0          0
Normal                               0         0         0         0          0
Medium                               0         0         0         0          0
High                                 0         0         0         0          0
Crucial                              0         0         0         0          0
Super Crucial                        0         0         0         0          0
Packets Dropped In Processing by Priority
Unknown                            152         0         0         0          0
Normal                               0         0         0         0          0
Medium                      1940527769     16037     16493     13774      13102
High                                 0         0         0         0          0
Crucial                              6         0         0         0          0
Packets Not Enqueued by Reason
Reason            Total                5 sec avg 1 min avg 5 min avg 1 hour avg
RxQueueNotAvail                      0         0         0         0          0
RxNoBuffersAvail                     0         0         0         0          0
RxBadCpuEvent                        0         0         0         0          0
Testing                              0         0         0         0          0
Packets Dropped In Processing by Reason
NoPimPhyportMap                       0         0         0         0          0
NoPimPhyport                          0         0         0         0          0
NoK5PhyportForPhyportIdInFch                    0         0         0         0          0
UnimplementedEvt                      0         0         0         0          0
InvalidEvt                            0         0         0         0          0
SrcAddrTableFilt                      0         0         0         0          0
NoL2Vlan                              0         0         0         0          0
STPDrop                               0         0         0         0          0
UnknownLyr-Bridge                     0         0         0         0          0
UnknownLyr-OutAcl                     0         0         0         0          0
L2DstDrop                             0         0         0         0          0
L2DstDropOutAcl                       0         0         0         0          0
AclNoVlan                             0         0         0         0          0
AclActionDrop                         0         0         0         0          0
AclActionRedirect                     0         0         0         0          0
AclActionUnsupptd                     0         0         0         0          0
UnknownBridgeAct                      0         0         0         0          0
NoTxInfo                              0         0         0         0          0
NoDstPorts                            0         0         0         0          0
NoFloodPorts                          0         0         0         0          0
ControlNoL2DstEnt                     0         0         0         0          0
InvalidAclAction                      0         0         0         0          0
AclInputErr                           0         0         0         0          0
OutAclEvntOnInAcl                     0         0         0         0          0
AclOutputErr                          0         0         0         0          0
ReservedPort                          0         0         0         0          0
EsmpNoTxInfo                          0         0         0         0          0
UnknownSource                         0         0         0         0          0
NoDriverTxPacketInfo                    0         0         0         0          0
NoPimPort                             0         0         0         0          0
RouteLookupFailed                     0         0         0         0          0
FragPktAllocFailed                    0         0         0         0          0
Dont Fragment Drop                    0         0         0         0          0
IpHdrException                        0         0         0         0          0
Packet already Hw brigdged                    0         0         0         0          0
SpanEvent                             0         0         0         0          0
Dot1xUnauthCtrlPkt                    0         0         0         0          0
No Sw port for ARP                    0         0         0         0          0
No Sw port for ESMP                    0         0         0         0          0
Tx Mode Drop                 1940521691     16037     16493     13774      13102
Invalid TxInfo For Replica                    0         0         0         0          0
Qos Policer Drop                      6         0         0         0          0
Bad Crc                               0         0         0         0          0
Extra packet due to RxProc hwAssisted Bridging                    0         0         0         0          0
CtrlPktInBadEtherType                    0         0         0         0          0
PortMacOperationallyDown                    0         0         0         0          0
Extra packet received on VSS-Standby                    0         0         0         0          0
TX packet received on VSS-Active                    0         0         0         0          0
Failed to create VS Tunnel packet                    0         0         0         0          0
Standalone system received VS Tunnel packet                    0         0         0         0          0
Failed to decode VS Tunnel packet                    0         0         0         0          0
Failed to duplicate packet for remote port                    0         0         0         0          0
Packet does not contain any local TxInfos                 6078         0         0         0          0
No Vsl port found                     0         0         0         0          0
Local copy of Medianet packet received on VSS-Active                    0         0         0         0          0
L2 control packet Tx for Vsl port                    0         0         0         0          0
L2 control packet Rx on Vsl port                    0         0         0         0          0
System not SSO Hot yet                    0         0         0         0          0
L2 Ctrl Packet received as SA miss                  152         0         0         0          0
L3 Ctrl Packet copied to Standby                    0         0         0         0          0
Fnf packet export failed,no PV-Vrf mapping                    0         0         0         0          0
FnfExportedGleanPkts No SVI Drop                    0         0         0         0          0
No Ebm Vlan                           0         0         0         0          0
NoPimPhyport on Standby                    0         0         0         0          0
Vsl port connected to non-vsl port                    0         0         0         0          0
Invalid Vs Mgmt Pak received                    0         0         0         0          0
Invalid EVC packet                    0         0         0         0          0
Unknown EVC packet                    0         0         0         0          0
Invalid Vlan packet                    0         0         0         0          0
Efp not present for Tx packet                    0         0         0         0          0
No space available for EVC shim hdr                    0         0         0         0          0
EVC captured packet                    0         0         0         0          0
QinQ Tag Insert Failed                    0         0         0         0          0
PktSampEncap Fail Drop                    0         0         0         0          0
PktSampCpuBoundPkt Drop                    0         0         0         0          0
PktSampExportedGleanPkts No SVI Drop                    0         0         0         0          0
Total packet queues 64
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Unknown                              0         0         0         0          0
Esmp                                 0         0         0         0          0
Input ACL fwd(snooping)               0         0         0         0          0
L2 router to CPU, 0                  0         0         0         0          0
Vslp                          14882993         2         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Host Learning                    60940         0         0         0          0
L2 Control                     1712033         8         0         0          0
Input ACL log, unreach               0         0         0         0          0
L3 Glean                          6473         0         0         0          0
L2 router to CPU, 1                  0         0         0         0          0
Vs Mgmt                        9714500         2         0         2          1
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
L2 bridge to CPU                     0         0         0         0          0
Ip Option                            0         0         0         0          0
Input ACL sw processing               0         0         0         0          0
L3 Receive                       27528         0         0         0          0
L2 router to CPU, 2                  0         0         0         0          0
Vs Tunnel Ctrl Pkt            19656310         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Ttl Expired                      78254         0         0         0          0
Input ACL EPC Copy                   0         0         0         0          0
Rsvp                                 0         0         0         0          0
L2 router to CPU, 3                  0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
CTS Exception                        0         0         0         0          0
Non Arpa                             0         0         0         0          0
Output ACL fwd(snooping)               0         0         0         0          0
L2 router to CPU, 4                  0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
InputIf Fail                         0         0         0         0          0
UcastRpfFail                         0         0         0         0          0
Output ACL log, unreach               0         0         0         0          0
Bfd                               2483         0         0         0          0
L2 router to CPU, 5                  0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Ipv6 Scope Check Fail                0         0         0         0          0
SrcIndex Check Fail                  0         0         0         0          0
Output ACL sw processing               0         0         0         0          0
Unknown                              0         0         0         0          0
L2 router to CPU, 6                  0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Mtu Fail                             0         0         0         0          0
Adj SameIf Fail                      0         0         0         0          0
Output ACL EPC Copy                  0         0         0         0          0
Unknown                              0         0         0         0          0
L2 router to CPU, 7            4458323        21        17        17          8
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Dropped by Packet Queue
Unknown                              0         0         0         0          0
Esmp                                 0         0         0         0          0
Vslp                                 0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Host Learning                        0         0         0         0          0
L3 Glean                             0         0         0         0          0
Vs Mgmt                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Ip Option                            0         0         0         0          0
Vs Tunnel Ctrl Pkt                   0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Ttl Expired                          0         0         0         0          0
Rsvp                                 0         0         0         0          0
Vs Tunnel Data Pkt              942799         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Non Arpa                             0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Bfd                                  0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Mtu Fail                             0         0         0         0          0
Unknown                              0         0         0         0          0
L2 router to CPU, 7                  0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Packets Transmitted from CPU per Output Interface
Interface              Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Gi1/2/1                              0         0         0         0          0
Gi1/2/2                              0         0         0         0          0
Gi1/2/3                              0         0         0         0          0
Gi1/2/4                              0         0         0         0          0
Gi1/2/5                              0         0         0         0          0
Gi1/2/6                              0         0         0         0          0
Gi1/2/7                              0         0         0         0          0
Gi1/2/8                              0         0         0         0          0
Gi1/2/9                              0         0         0         0          0
Gi1/2/10                             0         0         0         0          0
Gi1/2/11                             0         0         0         0          0
Gi1/2/12                             0         0         0         0          0
Gi1/2/13                             0         0         0         0          0
Gi1/2/14                             0         0         0         0          0
Gi1/2/15                             0         0         0         0          0
Gi1/2/16                             0         0         0         0          0
Gi1/2/17                             0         0         0         0          0
Gi1/2/18                             0         0         0         0          0
Gi1/2/19                             0         0         0         0          0
Gi1/2/20                             0         0         0         0          0
Gi1/2/21                             0         0         0         0          0
Gi1/2/22                             0         0         0         0          0
Gi1/2/23                             0         0         0         0          0
Gi1/2/24                             0         0         0         0          0
Gi1/2/25                             0         0         0         0          0
Gi1/2/26                             0         0         0         0          0
Gi1/2/27                             0         0         0         0          0
Gi1/2/28                             0         0         0         0          0
Gi1/2/29                             0         0         0         0          0
Gi1/2/30                             0         0         0         0          0
Gi1/2/31                             0         0         0         0          0
Gi1/2/32                             0         0         0         0          0
Gi1/2/33                             0         0         0         0          0
Gi1/2/34                             0         0         0         0          0
Gi1/2/35                             0         0         0         0          0
Gi1/2/36                             0         0         0         0          0
Gi1/2/37                             0         0         0         0          0
Gi1/2/38                             0         0         0         0          0
Gi1/2/39                             0         0         0         0          0
Gi1/2/40                             0         0         0         0          0
Gi1/2/41                             0         0         0         0          0
Gi1/2/42                             0         0         0         0          0
Gi1/2/43                             0         0         0         0          0
Gi1/2/44                             0         0         0         0          0
Gi1/2/45                             0         0         0         0          0
Gi1/2/46                             0         0         0         0          0
Gi1/2/47                             0         0         0         0          0
Gi1/2/48                             0         0         0         0          0
Te1/1/1                              0         0         0         0          0
Te1/1/2                              0         0         0         0          0
Te1/1/3                              0         0         0         0          0
Te1/1/4                              0         0         0         0          0
Gi2/2/1                              0         0         0         0          0
Gi2/2/2                              0         0         0         0          0
Gi2/2/3                              0         0         0         0          0
Gi2/2/4                              0         0         0         0          0
Gi2/2/5                              0         0         0         0          0
Gi2/2/6                              0         0         0         0          0
Gi2/2/7                              0         0         0         0          0
Gi2/2/8                              0         0         0         0          0
Gi2/2/9                              0         0         0         0          0
Gi2/2/10                             0         0         0         0          0
Gi2/2/11                             0         0         0         0          0
Gi2/2/12                             0         0         0         0          0
Gi2/2/13                             0         0         0         0          0
Gi2/2/14                             0         0         0         0          0
Gi2/2/15                             0         0         0         0          0
Gi2/2/16                             0         0         0         0          0
Gi2/2/17                             0         0         0         0          0
Gi2/2/18                             0         0         0         0          0
Gi2/2/19                             0         0         0         0          0
Gi2/2/20                             0         0         0         0          0
Gi2/2/21                             0         0         0         0          0
Gi2/2/22                             0         0         0         0          0
Gi2/2/23                             0         0         0         0          0
Gi2/2/24                             0         0         0         0          0
Gi2/2/25                             0         0         0         0          0
Gi2/2/26                             0         0         0         0          0
Gi2/2/27                             0         0         0         0          0
Gi2/2/28                             0         0         0         0          0
Gi2/2/29                             0         0         0         0          0
Gi2/2/30                             0         0         0         0          0
Gi2/2/31                             0         0         0         0          0
Gi2/2/32                             0         0         0         0          0
Gi2/2/33                             0         0         0         0          0
Gi2/2/34                             0         0         0         0          0
Gi2/2/35                             0         0         0         0          0
Gi2/2/36                             0         0         0         0          0
Gi2/2/37                             0         0         0         0          0
Gi2/2/38                             0         0         0         0          0
Gi2/2/39                             0         0         0         0          0
Gi2/2/40                             0         0         0         0          0
Gi2/2/41                             0         0         0         0          0
Gi2/2/42                             0         0         0         0          0
Gi2/2/43                             0         0         0         0          0
Gi2/2/44                             0         0         0         0          0
Gi2/2/45                             0         0         0         0          0
Gi2/2/46                             0         0         0         0          0
Gi2/2/47                             0         0         0         0          0
Gi2/2/48                             0         0         0         0          0
Te2/1/1                              0         0         0         0          0
Te2/1/2                              0         0         0         0          0
Te2/1/3                              0         0         0         0          0
Te2/1/4                              0         0         0         0          0
Packets Received at CPU per Input Interface
Gi1/2/1                              0         0         0         0          0
Gi1/2/2                              0         0         0         0          0
Gi1/2/3                              0         0         0         0          0
Gi1/2/4                              0         0         0         0          0
Gi1/2/5                              0         0         0         0          0
Gi1/2/6                              0         0         0         0          0
Gi1/2/7                              0         0         0         0          0
Gi1/2/8                              0         0         0         0          0
Gi1/2/9                              0         0         0         0          0
Gi1/2/10                             0         0         0         0          0
Gi1/2/11                             0         0         0         0          0
Gi1/2/12                             0         0         0         0          0
Gi1/2/13                             0         0         0         0          0
Gi1/2/14                             0         0         0         0          0
Gi1/2/15                             0         0         0         0          0
Gi1/2/16                             0         0         0         0          0
Gi1/2/17                             0         0         0         0          0
Gi1/2/18                             0         0         0         0          0
Gi1/2/19                             0         0         0         0          0
Gi1/2/20                             0         0         0         0          0
Gi1/2/21                             0         0         0         0          0
Gi1/2/22                             0         0         0         0          0
Gi1/2/23                             0         0         0         0          0
Gi1/2/24                             0         0         0         0          0
Gi1/2/25                             0         0         0         0          0
Gi1/2/26                             0         0         0         0          0
Gi1/2/27                             0         0         0         0          0
Gi1/2/28                             0         0         0         0          0
Gi1/2/29                             0         0         0         0          0
Gi1/2/30                             0         0         0         0          0
Gi1/2/31                             0         0         0         0          0
Gi1/2/32                             0         0         0         0          0
Gi1/2/33                             0         0         0         0          0
Gi1/2/34                             0         0         0         0          0
Gi1/2/35                             0         0         0         0          0
Gi1/2/36                             0         0         0         0          0
Gi1/2/37                             0         0         0         0          0
Gi1/2/38                             0         0         0         0          0
Gi1/2/39                             0         0         0         0          0
Gi1/2/40                             0         0         0         0          0
Gi1/2/41                             0         0         0         0          0
Gi1/2/42                             0         0         0         0          0
Gi1/2/43                             0         0         0         0          0
Gi1/2/44                             0         0         0         0          0
Gi1/2/45                             0         0         0         0          0
Gi1/2/46                             0         0         0         0          0
Gi1/2/47                             0         0         0         0          0
Gi1/2/48                             0         0         0         0          0
Te1/1/1                              0         0         0         0          0
Te1/1/2                              0         0         0         0          0
Te1/1/3                              0         0         0         0          0
Te1/1/4                              0         0         0         0          0
Gi2/2/1                              0         0         0         0          0
Gi2/2/2                              0         0         0         0          0
Gi2/2/3                              0         0         0         0          0
Gi2/2/4                              0         0         0         0          0
Gi2/2/5                              0         0         0         0          0
Gi2/2/6                              0         0         0         0          0
Gi2/2/7                              0         0         0         0          0
Gi2/2/8                              0         0         0         0          0
Gi2/2/9                              0         0         0         0          0
Gi2/2/10                             0         0         0         0          0
Gi2/2/11                             0         0         0         0          0
Gi2/2/12                             0         0         0         0          0
Gi2/2/13                             0         0         0         0          0
Gi2/2/14                             0         0         0         0          0
Gi2/2/15                             0         0         0         0          0
Gi2/2/16                             0         0         0         0          0
Gi2/2/17                             0         0         0         0          0
Gi2/2/18                             0         0         0         0          0
Gi2/2/19                             0         0         0         0          0
Gi2/2/20                             0         0         0         0          0
Gi2/2/21                             0         0         0         0          0
Gi2/2/22                             0         0         0         0          0
Gi2/2/23                             0         0         0         0          0
Gi2/2/24                             0         0         0         0          0
Gi2/2/25                             0         0         0         0          0
Gi2/2/26                             0         0         0         0          0
Gi2/2/27                             0         0         0         0          0
Gi2/2/28                             0         0         0         0          0
Gi2/2/29                             0         0         0         0          0
Gi2/2/30                             0         0         0         0          0
Gi2/2/31                             0         0         0         0          0
Gi2/2/32                             0         0         0         0          0
Gi2/2/33                             0         0         0         0          0
Gi2/2/34                             0         0         0         0          0
Gi2/2/35                             0         0         0         0          0
Gi2/2/36                             0         0         0         0          0
Gi2/2/37                             0         0         0         0          0
Gi2/2/38                             0         0         0         0          0
Gi2/2/39                             0         0         0         0          0
Gi2/2/40                             0         0         0         0          0
Gi2/2/41                             0         0         0         0          0
Gi2/2/42                             0         0         0         0          0
Gi2/2/43                             0         0         0         0          0
Gi2/2/44                             0         0         0         0          0
Gi2/2/45                             0         0         0         0          0
Gi2/2/46                             0         0         0         0          0
Gi2/2/47                             0         0         0         0          0
Gi2/2/48                             0         0         0         0          0
Te2/1/1                              0         0         0         0          0
Te2/1/2                              0         0         0         0          0
Te2/1/3                              0         0         0         0          0
Te2/1/4                              0         0         0         0          0
Executing the command on VSS member switch role = VSS Standby, id = 1
           0               0               0               0               0
           1               0               0               0               0
           2               0               0               0               0
           3               0               0               0               0
           4               0               0               0               0
           5               0               0               0               0
           6               0               0               0               0
           7               0               0               0               0
           0               0               0               0               0
           1               0               0               0               0
           2               0               0               0               0
           3               0               0               0               0
           4               0               0               0               0
           5               0               0               0               0
           6               0               0               0               0
           7               0               0               0               0
RkGenericPacketMan:
                   0         0         0         0          0
                   0         0         0         0          0
              347971         1         0         0          0
Unknown                              0         0         0         0          0
Sa Miss                              0         0         0         0          0
Nfe                                  0         0         0         0          0
CTS                                  0         0         0         0          0
ESMP                                 0         0         0         0          0
Non Arpa                             0         0         0         0          0
Ip Option                            0         0         0         0          0
L2 Bridge                            0         0         0         0          0
Rsvp                                 0         0         0         0          0
Rtp                                  0         0         0         0          0
L2 Router                            0         0         0         0          0
L3 Glean                             0         0         0         0          0
VSLP                                 0         0         0         0          0
VS Mgmt                              0         0         0         0          0
Unknown                              0         0         0         0          0
Sa Miss                              0         0         0         0          0
Nfe                                  0         0         0         0          0
CTS                                  0         0         0         0          0
ESMP                                 0         0         0         0          0
Non Arpa                             0         0         0         0          0
Ip Option                            0         0         0         0          0
L2 Bridge                            0         0         0         0          0
Rsvp                                 0         0         0         0          0
Rtp                                  0         0         0         0          0
L2 Router                            0         0         0         0          0
L3 Glean                             0         0         0         0          0
VSLP                                 0         0         0         0          0
VS Mgmt                              0         0         0         0          0
Vs Tunnel Control               347971         1         0         0          0
Unknown                              0         0         0         0          0
Normal                               0         0         0         0          0
Medium                               0         0         0         0          0
High                                 0         0         0         0          0
Crucial                              0         0         0         0          0
Unknown                         347971         1         0         0          0
Normal                               0         0         0         0          0
Medium                               0         0         0         0          0
High                                 0         0         0         0          0
Crucial                              0         0         0         0          0
Testing                              0         0         0         0          0
NoL2Vlan                              0         0         0         0          0
STPDrop                               0         0         0         0          0
L2DstDrop                             0         0         0         0          0
AclNoVlan                             0         0         0         0          0
NoTxInfo                              0         0         0         0          0
NoPimPort                             0         0         0         0          0
SpanEvent                             0         0         0         0          0
Tx Mode Drop                          0         0         0         0          0
Qos Policer Drop                      0         0         0         0          0
Bad Crc                               0         0         0         0          0
Packet does not contain any local TxInfos                    0         0         0         0          0
System not SSO Hot yet                 1311         0         0         0          0
L2 Ctrl Packet received as SA miss               346660         1         0         0          0
Unknown                              0         0         0         0          0
Esmp                                 0         0         0         0          0
Vslp                            466220         2         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Host Learning               1931972987     16934     16744     13623      13034
L2 Control                          16         0         0         0          0
L3 Glean                             0         0         0         0          0
Vs Mgmt                         334850         1         0         1          1
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Ip Option                            9         0         0         0          0
Vs Tunnel Ctrl Pkt             1484611         7         1         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Ttl Expired                       6047         0         0         0          0
Rsvp                                 0         0         0         0          0
Vs Tunnel Data Pkt               77834         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Non Arpa                             0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Bfd                               1490         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Mtu Fail                             0         0         0         0          0
Unknown                              0         0         0         0          0
L2 router to CPU, 7                239         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
Esmp                                 0         0         0         0          0
Vslp                                 0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Host Learning                 13528758         0         0         0          3
L3 Glean                             0         0         0         0          0
Vs Mgmt                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Ip Option                            0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Rsvp                                 0         0         0         0          0
Vs Tunnel Data Pkt                   0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Non Arpa                             0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Bfd                                  0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Mtu Fail                             0         0         0         0          0
Unknown                              0         0         0         0          0
Unknown                              0         0         0         0          0
L3 Fwd                               0         0         0         0          0
Unknown                              0         0         0         0          0
Gi1/2/1                              0         0         0         0          0
Gi1/2/2                              0         0         0         0          0
Gi1/2/3                              0         0         0         0          0
Gi1/2/4                              0         0         0         0          0
Gi1/2/5                              0         0         0         0          0
Gi1/2/6                              0         0         0         0          0
Gi1/2/7                              0         0         0         0          0
Gi1/2/8                              0         0         0         0          0
Gi1/2/9                              0         0         0         0          0
Gi1/2/10                             0         0         0         0          0
Gi1/2/11                             0         0         0         0          0
Gi1/2/12                             0         0         0         0          0
Gi1/2/13                             0         0         0         0          0
Gi1/2/14                             0         0         0         0          0
Gi1/2/15                             0         0         0         0          0
Gi1/2/16                             0         0         0         0          0
Gi1/2/17                             0         0         0         0          0
Gi1/2/18                             0         0         0         0          0
Gi1/2/19                             0         0         0         0          0
Gi1/2/20                             0         0         0         0          0
Gi1/2/21                             0         0         0         0          0
Gi1/2/22                             0         0         0         0          0
Gi1/2/23                             0         0         0         0          0
Gi1/2/24                             0         0         0         0          0
Gi1/2/25                             0         0         0         0          0
Gi1/2/26                             0         0         0         0          0
Gi1/2/27                             0         0         0         0          0
Gi1/2/28                             0         0         0         0          0
Gi1/2/29                             0         0         0         0          0
Gi1/2/30                             0         0         0         0          0
Gi1/2/31                             0         0         0         0          0
Gi1/2/32                             0         0         0         0          0
Gi1/2/33                             0         0         0         0          0
Gi1/2/34                             0         0         0         0          0
Gi1/2/35                             0         0         0         0          0
Gi1/2/36                             0         0         0         0          0
Gi1/2/37                             0         0         0         0          0
Gi1/2/38                             0         0         0         0          0
Gi1/2/39                             0         0         0         0          0
Gi1/2/40                             0         0         0         0          0
Gi1/2/41                             0         0         0         0          0
Gi1/2/42                             0         0         0         0          0
Gi1/2/43                             0         0         0         0          0
Gi1/2/44                             0         0         0         0          0
Gi1/2/45                             0         0         0         0          0
Gi1/2/46                             0         0         0         0          0
Gi1/2/47                             0         0         0         0          0
Gi1/2/48                             0         0         0         0          0
Te1/1/1                              0         0         0         0          0
Te1/1/2                              0         0         0         0          0
Te1/1/3                              0         0         0         0          0
Te1/1/4                              0         0         0         0          0
Gi2/2/1                              0         0         0         0          0
Gi2/2/2                              0         0         0         0          0
Gi2/2/3                              0         0         0         0          0
Gi2/2/4                              0         0         0         0          0
Gi2/2/5                              0         0         0         0          0
Gi2/2/6                              0         0         0         0          0
Gi2/2/7                              0         0         0         0          0
Gi2/2/8                              0         0         0         0          0
Gi2/2/9                              0         0         0         0          0
Gi2/2/10                             0         0         0         0          0
Gi2/2/11                             0         0         0         0          0
Gi2/2/12                             0         0         0         0          0
Gi2/2/13                             0         0         0         0          0
Gi2/2/14                             0         0         0         0          0
Gi2/2/15                             0         0         0         0          0
Gi2/2/16                             0         0         0         0          0
Gi2/2/17                             0         0         0         0          0
Gi2/2/18                             0         0         0         0          0
Gi2/2/19                             0         0         0         0          0
Gi2/2/20                             0         0         0         0          0
Gi2/2/21                             0         0         0         0          0
Gi2/2/22                             0         0         0         0          0
Gi2/2/23                             0         0         0         0          0
Gi2/2/24                             0         0         0         0          0
Gi2/2/25                             0         0         0         0          0
Gi2/2/26                             0         0         0         0          0
Gi2/2/27                             0         0         0         0          0
Gi2/2/28                             0         0         0         0          0
Gi2/2/29                             0         0         0         0          0
Gi2/2/30                             0         0         0         0          0
Gi2/2/31                             0         0         0         0          0
Gi2/2/32                             0         0         0         0          0
Gi2/2/33                             0         0         0         0          0
Gi2/2/34                             0         0         0         0          0
Gi2/2/35                             0         0         0         0          0
Gi2/2/36                             0         0         0         0          0
Gi2/2/37                             0         0         0         0          0
Gi2/2/38                             0         0         0         0          0
Gi2/2/39                             0         0         0         0          0
Gi2/2/40                             0         0         0         0          0
Gi2/2/41                             0         0         0         0          0
Gi2/2/42                             0         0         0         0          0
Gi2/2/43                             0         0         0         0          0
Gi2/2/44                             0         0         0         0          0
Gi2/2/45                             0         0         0         0          0
Gi2/2/46                             0         0         0         0          0
Gi2/2/47                             0         0         0         0          0
Gi2/2/48                             0         0         0         0          0
Te2/1/1                              0         0         0         0          0
Te2/1/2                              0         0         0         0          0
Te2/1/3                              0         0         0         0          0
Te2/1/4                              0         0         0         0          0
Gi1/2/1                              0         0         0         0          0
Gi1/2/2                              0         0         0         0          0
Gi1/2/3                              0         0         0         0          0
Gi1/2/4                              0         0         0         0          0
Gi1/2/5                              0         0         0         0          0
Gi1/2/6                              0         0         0         0          0
Gi1/2/7                              0         0         0         0          0
Gi1/2/8                              0         0         0         0          0
Gi1/2/9                              0         0         0         0          0
Gi1/2/10                             0         0         0         0          0
Gi1/2/11                             0         0         0         0          0
Gi1/2/12                             0         0         0         0          0
Gi1/2/13                             0         0         0         0          0
Gi1/2/14                             0         0         0         0          0
Gi1/2/15                             0         0         0         0          0
Gi1/2/16                             0         0         0         0          0
Gi1/2/17                             0         0         0         0          0
Gi1/2/18                             0         0         0         0          0
Gi1/2/19                             0         0         0         0          0
Gi1/2/20                             0         0         0         0          0
Gi1/2/21                             0         0         0         0          0
Gi1/2/22                             0         0         0         0          0
Gi1/2/23                             0         0         0         0          0
Gi1/2/24                             0         0         0         0          0
Gi1/2/25                             0         0         0         0          0
Gi1/2/26                             0         0         0         0          0
Gi1/2/27                             0         0         0         0          0
Gi1/2/28                             0         0         0         0          0
Gi1/2/29                             0         0         0         0          0
Gi1/2/30                             0         0         0         0          0
Gi1/2/31                             0         0         0         0          0
Gi1/2/32                             0         0         0         0          0
Gi1/2/33                             0         0         0         0          0
Gi1/2/34                             0         0         0         0          0
Gi1/2/35                             0         0         0         0          0
Gi1/2/36                             0         0         0         0          0
Gi1/2/37                             0         0         0         0          0
Gi1/2/38                             0         0         0         0          0
Gi1/2/39                             0         0         0         0          0
Gi1/2/40                             0         0         0         0          0
Gi1/2/41                             0         0         0         0          0
Gi1/2/42                             0         0         0         0          0
Gi1/2/43                             0         0         0         0          0
Gi1/2/44                             0         0         0         0          0
Gi1/2/45                             0         0         0         0          0
Gi1/2/46                             0         0         0         0          0
Gi1/2/47                             0         0         0         0          0
Gi1/2/48                             0         0         0         0          0
Te1/1/1                              0         0         0         0          0
Te1/1/2                              0         0         0         0          0
Te1/1/3                              0         0         0         0          0
Te1/1/4                              0         0         0         0          0
Gi2/2/1                              0         0         0         0          0
Gi2/2/2                              0         0         0         0          0
Gi2/2/3                              0         0         0         0          0
Gi2/2/4                              0         0         0         0          0
Gi2/2/5                              0         0         0         0          0
Gi2/2/6                              0         0         0         0          0
Gi2/2/7                              0         0         0         0          0
Gi2/2/8                              0         0         0         0          0
Gi2/2/9                              0         0         0         0          0
Gi2/2/10                             0         0         0         0          0
Gi2/2/11                             0         0         0         0          0
Gi2/2/12                             0         0         0         0          0
Gi2/2/13                             0         0         0         0          0
Gi2/2/14                             0         0         0         0          0
Gi2/2/15                             0         0         0         0          0
Gi2/2/16                             0         0         0         0          0
Gi2/2/17                             0         0         0         0          0
Gi2/2/18                             0         0         0         0          0
Gi2/2/19                             0         0         0         0          0
Gi2/2/20                             0         0         0         0          0
Gi2/2/21                             0         0         0         0          0
Gi2/2/22                             0         0         0         0          0
Gi2/2/23                             0         0         0         0          0
Gi2/2/24                             0         0         0         0          0
Gi2/2/25                             0         0         0         0          0
Gi2/2/26                             0         0         0         0          0
Gi2/2/27                             0         0         0         0          0
Gi2/2/28                             0         0         0         0          0
Gi2/2/29                             0         0         0         0          0
Gi2/2/30                             0         0         0         0          0
Gi2/2/31                             0         0         0         0          0
Gi2/2/32                             0         0         0         0          0
Gi2/2/33                             0         0         0         0          0
Gi2/2/34                             0         0         0         0          0
Gi2/2/35                             0         0         0         0          0
Gi2/2/36                             0         0         0         0          0
Gi2/2/37                             0         0         0         0          0
Gi2/2/38                             0         0         0         0          0
Gi2/2/39                             0         0         0         0          0
Gi2/2/40                             0         0         0         0          0
Gi2/2/41                             0         0         0         0          0
Gi2/2/42                             0         0         0         0          0
Gi2/2/43                             0         0         0         0          0
Gi2/2/44                             0         0         0         0          0
Gi2/2/45                             0         0         0         0          0
Gi2/2/46                             0         0         0         0          0
Gi2/2/47                             0         0         0         0          0
Gi2/2/48                             0         0         0         0          0
Te2/1/1                              0         0         0         0          0
Te2/1/2                              0         0         0         0          0
Te2/1/3                              0         0         0         0          0
Te2/1/4                              0         0         0         0          0
RkGenericPacketMan:
          1940650236     16882     16562     13774      13102
Sa Miss                     1940644000     16882     16562     13774      13102
Unknown                            152         0         0         0          0
Medium                      1940650078     16882     16562     13774      13102
Crucial                              6         0         0         0          0
Tx Mode Drop                 1940644000     16882     16562     13774      13102
Vslp                          14883013         2         0         0          0
L2 Control                     1712104        10         0         0          0
Vs Mgmt                        9714585         3         0         2          1
Vs Tunnel Data Pkt          1913873410     16712     16257     13467      12827
Bfd                               2483         0         0         0          0
L2 router to CPU, 7            4458483        23        17        17          8
RkGenericPacketMan:
              347981         1         0         0          0
Vs Tunnel Control               347981         1         0         0          0
Unknown                         347981         1         0         0          0
L2 Ctrl Packet received as SA miss               346670         1         0         0          0
Vslp                            466234         2         0         0          0
Host Learning               1932063040     15089     16547     13623      13034
Vs Mgmt                         334883         3         0         1          1
Ip Option                            9         0         0         0          0
Vs Tunnel Ctrl Pkt             1484657         7         1         0          0
Vs Tunnel Data Pkt               77838         0         0         0          0
Bfd                               1490         0         0         0          0
sw4501#Show platform health | ex 0.00
                     %CPU   %CPU    RunTimeMax   Priority  Average %CPU  Total
                     Target Actual Target Actual   Fg   Bg 5Sec Min Hour  CPU
RkiosObflMan           0.50   0.01      4     26  100  500    0   0    0  5:26
VSI slot-01            6.00   0.65      6     84  100  500    1   0    0  754:45
VSI backplane          6.00   0.01      6      3  100  500    0   0    0  27:53
VSI slot-02            6.00   5.43      6     75  100  500    5   4    3  3244:57
GalChassisVp           3.00   0.10     20    104  100  500    0   0    0  110:18
Lj-poll                1.00   0.01      2      4  100  500    0   0    0  27:00
StatValueMan Update    1.00   0.02      1     48  100  500    0   0    0  74:59
GalK5TatooineStatsMa   0.70   0.02      4      5  100  500    0   0    0  39:43
K5L3AdjStatsMan Revi   2.00   0.04     10     50  100  500    0   0    0  173:50
K5FlcHitMan review     2.00   0.02      5     33  100  500    0   0    0  266:11
K5PortMan Regular Re   2.00   0.26     15     94  100  500    0   0    0  294:52
K5PortMan Ondemand L   6.00   0.35     30     53  100  500    0   0    0  325:10
K5 L2 Aging Table Re   2.00   0.32     20     95  100  500    0   0    0  216:15
K5RetStatsMan Review   2.00   0.01      5     55  100  500    0   0    0  234:19
K5ForerunnerPacketMa   2.00   0.12      4     56  100  500    0   0    0  139:50
K5ForerunnerPacketMa   2.00   0.27      4     89  100  500    0   0    0  259:37
K5QosDhmMan Rate DBL   2.00   0.33      7     97  100  500    0   0    0  329:47
K5VlanStatsReview      2.00   1.18     10    121  100  500    1   1    0  1342:56
K5AclCamStatsMan hw    3.00   0.07     10     68  100  500    0   0    0  318:27
RkGenericL3Wccp IrmW   2.00   0.01     10      3  100  500    0   0    0  5:21
RkiosPortMan Port Re   2.00   0.27     12     49  100  500    0   0    0  197:27
Rkios Module State R   4.00   0.03     40     40  100  500    0   0    0  31:06
Rkios Online Diag Re   4.00   0.03     40     46  100  500    0   0    0  28:51
RkNovaL3Fib L3If Rev   2.00   0.02     10     24  100  500    0   0    0  28:59
PDS Rx Review          2.00   0.02     10     71  100  500    0   0    0  76:29
GalGlmLinecardVp(1)    5.00   0.29     20     99  100  500    0   0    0  276:04
Temperature monitor    0.40   0.01      4     53  100  500    0   0    0  17:23
GalGlmPollerMan        3.00   0.01     20      8  100  500    0   0    0  27:31
ResetDetect 1          0.40   0.01      4    119  100  500    0   0    0  16:25
Xgstub Stats Review    0.50   0.15      5     40  100  500    0   0    0  121:31
Stub CTS Periodic Re   0.80   0.05      8     42  100  500    0   0    0  64:53
Stub CTS PeriodicSta   0.80   0.09      8     68  100  500    0   0    0  127:04
Stub CTS Periodic Re   0.80   0.04      8     55  100  500    0   0    0  66:14
Stub CTS PeriodicSta   0.80   0.07      8     61  100  500    0   0    0  126:32
EpmPortGroup(10:N) s   0.50   0.03      2     48  100  500    0   0    0  59:49
GalGlmLinecardVp(2)    5.00   0.30     20    136  100  500    0   0    0  282:14
Temperature monitor    0.40   0.03      4     68  100  500    0   0    0  16:27
GalGlmPollerMan        3.00   0.01     20      3  100  500    0   0    0  27:21
Xgstub Stats Review    0.50   0.16      5    101  100  500    0   0    0  179:17
Stub CTS Periodic Re   0.80   0.07      8     19  100  500    0   0    0  100:31
Stub CTS PeriodicSta   0.80   0.10      8     92  100  500    0   0    0  102:01
Stub CTS Periodic Re   0.80   0.11      8     23  100  500    0   0    0  100:36
Stub CTS PeriodicSta   0.80   0.07      8    113  100  500    0   0    0  101:54
Stub CTS Periodic Re   0.80   0.08      8     50  100  500    0   0    0  101:03
Stub CTS PeriodicSta   0.80   0.07      8     75  100  500    0   0    0  101:51
Stub CTS Periodic Re   0.80   0.07      8     16  100  500    0   0    0  101:53
Stub CTS PeriodicSta   0.80   0.06      8     76  100  500    0   0    0  101:36
EpmPortGroup(11:N) s   0.50   0.06      2     53  100  500    0   0    0  67:55
%CPU Totals          317.20  70.74
                       Allocation ceiling        Current allocation
                       kbytes    % in use        kbytes    % in use
TSM objects            ------------------        ------------------
PacketInfoItem            781.25       0%            0.15        0%
VbufNodes1600              55.50       0%            5.20        0%
VbufNodes400              288.00       3%           10.68       94%
Packet                   2474.28       0%            0.21        0%
RkiosSysPacketBuf         281.25       0%            0.63        0%
K5InternalVlanIdMap        96.00       3%            3.00      100%
IrmFibUnicastRpfList     8192.00       0%            4.81       87%
K5QosTxQueSelTableBl       12.00       2%            0.32      100%
K5QosFeatureInfoList     2048.00       0%            1.62       46%
K5QosLabelToFeatureE     1792.00       0%            0.16       66%
K5QosPathFeatureInfo      384.00       0%            0.03      100%
MatEntrys               18432.00       0%            7.31      100%
MatEntryTableIterato        1.00       0%            0.03        0%
RkiosL3Port              2819.81       0%            2.95      100%
PimPhyports              1820.31      82%         1509.03      100%
PimPorts                 1237.50      90%         1118.90      100%
PimModules                296.00       1%            4.62      100%
PimSlots                   18.00       4%            0.84      100%
PimChassis                  8.25     100%            8.25      100%
PimQuack                    1.64       6%            0.10      100%
EbmVlans                 9152.00       0%           44.68      100%
EbmPorts                  487.50      90%          439.15      100%
EbmPortVlanAclFeatur     3456.00       0%            0.52      100%
EbmSortedHostTableIt        1.75       0%            0.05        0%
EbmSortedGroupTableI        1.75       0%            0.05        0%
EbmHostRedundancyMan     1082.81       0%            0.98      100%
EbmHostAgeRedundancy     1082.81       0%            1.96        0%
IrmVrfs                   628.00       1%            7.35      100%
IrmPortMemMan            7098.87       0%           10.71      100%
IrmFibEntries           12288.00       0%           13.92      100%
AclOp                    2176.00       0%            0.18      100%
AclOpAceSet              3808.00       0%            0.35      100%
AclFeature               2755.59       0%            3.41      100%
Acl                      1536.00       0%            5.01      100%
Ace48                   17408.00       0%            7.00      100%
AclListNode               512.00       0%            0.64       98%
AclLayerFeatureListN      512.00       0%            0.48       32%
FlatAcl                   512.00       0%            0.75       12%
FlatAce24               11264.00       0%           49.58       31%
FlatAce48               17408.00       0%            8.36       28%
FlatAclCacheNode         4224.00       0%            1.16       66%
FlatAclListNode           256.00       0%            0.29        0%
QosNestedClassifierA    15533.37       0%            1.58      100%
KxAclPath                1024.00       0%            0.40      100%
RkNovaFfmTokenMapEnt    88342.00       0%           28.90       99%
RkNovaFfmInvalidToke    12288.00       0%            0.14      100%
RkNova L3 PBR RouteM      512.00       0%            0.37      100%
RkNova L3 PBR RouteM     1718.75       0%            0.60      100%
RkNova L3 PBR RouteM      156.25       0%            0.05      100%
RkNovaQosQueues           104.25       0%            0.50      100%
RkNovaClassifClassMa     4096.00       0%            1.00      100%
RkNovaClassifClassMa      768.00       0%            0.72      100%
ffmToRkNovaClassifPo       96.00       0%            0.02      100%
RkNovaClassifPolicyM      575.71       0%            0.14      100%
KxAclLabeledFlatAcl      3584.00       0%            0.76       71%
KxAclLabeledFlatAclE     3072.00       0%            0.65       71%
EbmVlanHostEntrys        3222.65       0%            7.44       92%
VsiBuffers(128)           762.50       0%           20.50       31%
VsiBuffers(16)            146.87       0%           15.76        3%
VsiTransactions(1)        175.78       0%            7.61       15%
VsiTransactions(10)       380.85       2%           22.24       39%
VsiTransactions(18)       110.15       0%            8.81        0%
VsiTransactions(25)       126.56       0%            7.59        0%
VsiTransactions(80)       255.46       0%           17.03        0%
VsiTransactionRespon       45.31       1%            1.30       40%
VsiReqPool(s2w)            93.75       0%            3.65       15%
VsiReqPool(vli)          1117.18       1%           90.06       22%
VsiReqPool(mdio22)        468.75       0%           95.25        0%
VsiReqPool(mdio45)        328.12       0%            0.56        0%
GalGbicEntrys              38.67       0%            0.18      100%
K5L3FlcEntryAvlTree2    12902.39       0%           13.87      100%
K5FlowOperatorDescNo      612.00       0%            0.03        0%
K5AclLabelSignatureM    10368.00       0%            2.21       71%
InpTosMarkTbl BlockA       14.00       1%            0.21      100%
InpCosMarkTbl BlockA       14.00       1%            0.21      100%
InpExpMarkTbl BlockA       14.00       1%            0.21      100%
OutTosMarkTbl BlockA       14.00       1%            0.21      100%
OutCosMarkTbl BlockA       14.00       1%            0.21      100%
OutExpMarkTbl BlockA       14.00       1%            0.21      100%
K5TxPacketInfo            384.00       0%            0.07        0%
FlowTosMarkTbl Block       14.00       1%            0.21      100%
FlowCosMarkTbl Block       14.00       1%            0.21      100%
FlowExpMarkTbl Block       14.00       1%            0.21      100%
CommandTables              48.00      13%            6.65      100%
TSM totals             915447.00       0%         4202.73       87%
VSI slot-01            6.00   1.05      6     11  100  500    0   0    0  24:40
VSI backplane          6.00   0.01      6      1  100  500    0   0    0  0:51
VSI slot-02            6.00   5.30      6    105  100  500    4   4    3  121:01
GalChassisVp           3.00   0.09     20    104  100  500    0   0    0  3:28
Lj-poll                1.00   0.02      2      0  100  500    0   0    0  0:51
StatValueMan Update    1.00   0.07      1      4  100  500    0   0    0  2:18
GalK5TatooineStatsMa   0.70   0.02      4      6  100  500    0   0    0  1:15
K5L3AdjStatsMan Revi   2.00   0.04     10     20  100  500    0   0    0  5:28
K5FlcHitMan review     2.00   0.19      5     20  100  500    0   0    0  8:20
K5PortMan Regular Re   2.00   0.21     15    145  100  500    0   0    0  9:23
K5PortMan Ondemand L   6.00   0.33     30     23  100  500    0   0    0  10:22
K5 L2 Aging Table Re   2.00   0.28     20     23  100  500    0   0    0  6:46
K5RetStatsMan Review   2.00   0.09      5     37  100  500    0   0    0  7:24
K5ForerunnerPacketMa   2.00  24.87      4    132  100  500   33  30   23  691:36
K5ForerunnerPacketMa   2.00   0.23      4     54  100  500    0   0    0  8:07
K5QosDhmMan Rate DBL   2.00   0.31      7     50  100  500    0   0    0  10:20
K5VlanStatsReview      2.00   1.41     10    180  100  500    1   1    1  40:51
K5AclCamStatsMan hw    3.00   0.07     10     10  100  500    0   0    0  10:10
RkiosPortMan Port Re   2.00   0.17     12      7  100  500    0   0    0  5:59
Rkios Module State R   4.00   0.03     40      6  100  500    0   0    0  1:04
Rkios Online Diag Re   4.00   0.03     40     13  100  500    0   0    0  0:59
RkNovaL3Fib L3If Rev   2.00   0.01     10      1  100  500    0   0    0  0:54
PDS Rx Review          2.00   0.26     10      9  100  500    0   0    0  2:31
GalGlmLinecardVp(1)    5.00   0.28     20     99  100  500    0   0    0  8:43
GalGlmPollerMan        3.00   0.01     20      0  100  500    0   0    0  0:52
Stub ondemand global   0.50   0.02      5      4  100  500    0   0    0  0:28
Xgstub Stats Review    0.50   0.12      5      5  100  500    0   0    0  4:06
Stub CTS Periodic Re   0.80   0.04      8      9  100  500    0   0    0  2:07
Stub CTS PeriodicSta   0.80   0.17      8      6  100  500    0   0    0  2:38
Stub CTS Periodic Re   0.80   0.05      8      6  100  500    0   0    0  2:23
Stub CTS PeriodicSta   0.80   0.05      8      6  100  500    0   0    0  4:11
EpmPortGroup(0:N) st   0.50   0.04      2      2  100  500    0   0    0  1:53
GalGlmLinecardVp(2)    5.00   0.31     20    135  100  500    0   0    0  8:56
Temperature monitor    0.40   0.02      4      4  100  500    0   0    0  0:34
GalGlmPollerMan        3.00   0.01     20      1  100  500    0   0    0  0:52
Xgstub Stats Review    0.50   0.14      5     15  100  500    0   0    0  5:47
EthPhyControllerMan(   0.40   0.15      4      6  100  500    0   0    0  1:19
EthPhyControllerMan(   0.20   0.03      2      5  100  500    0   0    0  0:16
Stub CTS Periodic Re   0.80   0.07      8      9  100  500    0   0    0  3:21
Stub CTS PeriodicSta   0.80   0.05      8      7  100  500    0   0    0  3:32
Stub CTS Periodic Re   0.80   0.07      8     16  100  500    0   0    0  3:14
Stub CTS PeriodicSta   0.80   0.30      8     29  100  500    0   0    0  3:31
Stub CTS Periodic Re   0.80   0.06      8      7  100  500    0   0    0  3:14
Stub CTS PeriodicSta   0.80   0.30      8     16  100  500    0   0    0  3:32
Stub CTS Periodic Re   0.80   0.07      8      7  100  500    0   0    0  3:13
EpmPortGroup(1:N) st   0.50   0.05      2      6  100  500    0   0    0  2:11
%CPU Totals          317.20  99.09
VbufNodes1600              55.50       0%            3.46        0%
Packet                   2474.28       0%            0.10        0%
RkiosSysPacketBuf         281.25       0%            0.07        0%
IrmFibUnicastRpfList     8192.00       0%            4.25       99%
K5QosFeatureInfoList     2048.00       0%            1.18       63%
K5QosLabelToFeatureE     1792.00       0%            0.10      100%
EbmHostRedundancyMan     1082.81       0%            0.98        0%
EbmHostAgeRedundancy     1082.81       0%            1.96       50%
AclLayerFeatureListN      512.00       0%            0.37       41%
FlatAcl                   512.00       0%            0.73       12%
FlatAce24               11264.00       0%           34.89       44%
FlatAce48               17408.00       0%            6.24       38%
FlatAclCacheNode         4224.00       0%            0.77      100%
RkNovaFfmTokenMapEnt    88342.00       0%           28.12       99%
KxAclLabeledFlatAcl      3584.00       0%            0.54      100%
KxAclLabeledFlatAclE     3072.00       0%            0.46      100%
EbmVlanHostEntrys        3222.65       0%            7.14       95%
VsiBuffers(128)           762.50       0%           15.50       41%
VsiTransactions(1)        175.78       0%            7.14       16%
VsiTransactions(10)       380.85       2%           18.58       47%
VsiTransactionRespon       45.31       1%            1.23       43%
VsiReqPool(vli)          1117.18       1%           62.47       32%
K5AclLabelSignatureM    10368.00       0%            1.58      100%
K5TxPacketInfo            384.00       0%            0.02        0%
TSM totals             915447.00       0%         4069.19       90%
sw4501#  show spanning-tree summary
Switch is in pvst mode
Root bridge for: VLAN0036, VLAN0218, VLAN0999
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
EtherChannel misconfig guard is enabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Configured Pathcost method used is short
Name                   Blocking Listening Learning Forwarding STP Active
VLAN0017                     0         0        0          1          1
VLAN0018                     0         0        0          1          1
VLAN0024                     0         0        0          1          1
VLAN0035                     0         0        0          3          3
VLAN0036                     0         0        0          2          2
VLAN0039                     0         0        0          1          1
VLAN0040                     0         0        0          1          1
VLAN0048                     0         0        0          1          1
VLAN0049                     0         0        0          1          1
VLAN0215                     0         0        0          1          1
VLAN0218                     0         0        0          1          1
VLAN0999                     0         0        0          4          4
VLAN4050                     0         0        0          1          1
VLAN4051                     0         0        0          5          5
14 vlans                     0         0        0         24         24
sw4501#show spann det | in ieee|from|occur|is exec
VLAN0017 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 1 last change occurred 2d16h ago
VLAN0018 is executing the ieee compatible Spanning Tree protocol
VLAN0024 is executing the ieee compatible Spanning Tree protocol
VLAN0035 is executing the ieee compatible Spanning Tree protocol
VLAN0036 is executing the ieee compatible Spanning Tree protocol
VLAN0039 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 2 last change occurred 2d16h ago
VLAN0040 is executing the ieee compatible Spanning Tree protocol
VLAN0048 is executing the ieee compatible Spanning Tree protocol
VLAN0049 is executing the ieee compatible Spanning Tree protocol
VLAN0215 is executing the ieee compatible Spanning Tree protocol
VLAN0218 is executing the ieee compatible Spanning Tree protocol
VLAN0999 is executing the ieee compatible Spanning Tree protocol
          from GigabitEthernet1/2/40
VLAN4050 is executing the ieee compatible Spanning Tree protocol
VLAN4051 is executing the ieee compatible Spanning Tree protocol
sw4501#show interface | include line|drops
FastEthernet1 is up, line protocol is up
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
     0 unknown protocol drops
TenGigabitEthernet1/1/1 is up, line protocol is up (connected)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 218
TenGigabitEthernet1/1/2 is up, line protocol is up (connected)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 136
TenGigabitEthernet1/1/3 is administratively down, line protocol is down (disabled)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
TenGigabitEthernet1/1/4 is administratively down, line protocol is down (disabled)
GigabitEthernet1/2/1 is up, line protocol is up (connected)
GigabitEthernet1/2/2 is down, line protocol is down (notconnect)
GigabitEthernet1/2/3 is down, line protocol is down (notconnect)
GigabitEthernet1/2/4 is down, line protocol is down (notconnect)
GigabitEthernet1/2/5 is down, line protocol is down (notconnect)
GigabitEthernet1/2/6 is down, line protocol is down (notconnect)
GigabitEthernet1/2/7 is down, line protocol is down (notconnect)
GigabitEthernet1/2/8 is down, line protocol is down (notconnect)
GigabitEthernet1/2/9 is down, line protocol is down (notconnect)
GigabitEthernet1/2/10 is down, line protocol is down (notconnect)
GigabitEthernet1/2/11 is down, line protocol is down (notconnect)
GigabitEthernet1/2/12 is down, line protocol is down (notconnect)
GigabitEthernet1/2/13 is down, line protocol is down (notconnect)
GigabitEthernet1/2/14 is down, line protocol is down (notconnect)
GigabitEthernet1/2/15 is down, line protocol is down (notconnect)
GigabitEthernet1/2/16 is down, line protocol is down (notconnect)
GigabitEthernet1/2/17 is down, line protocol is down (notconnect)
GigabitEthernet1/2/18 is down, line protocol is down (notconnect)
GigabitEthernet1/2/19 is down, line protocol is down (notconnect)
GigabitEthernet1/2/20 is down, line protocol is down (notconnect)
GigabitEthernet1/2/21 is up, line protocol is up (connected)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 4473248
GigabitEthernet1/2/22 is up, line protocol is up (connected)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 13791004
GigabitEthernet1/2/23 is down, line protocol is down (notconnect)
GigabitEthernet1/2/24 is down, line protocol is down (notconnect)
GigabitEthernet1/2/25 is down, line protocol is down (notconnect)
GigabitEthernet1/2/26 is down, line protocol is down (notconnect)
GigabitEthernet1/2/27 is down, line protocol is down (notconnect)
GigabitEthernet1/2/28 is down, line protocol is down (notconnect)
GigabitEthernet1/2/29 is down, line protocol is down (notconnect)
GigabitEthernet1/2/30 is down, line protocol is down (notconnect)
GigabitEthernet1/2/31 is down, line protocol is down (notconnect)
GigabitEthernet1/2/32 is down, line protocol is down (notconnect)
GigabitEthernet1/2/33 is down, line protocol is down (notconnect)
GigabitEthernet1/2/34 is down, line protocol is down (notconnect)
GigabitEthernet1/2/35 is down, line protocol is down (notconnect)
GigabitEthernet1/2/36 is down, line protocol is down (notconnect)
GigabitEthernet1/2/37 is down, line protocol is down (notconnect)
GigabitEthernet1/2/38 is down, line protocol is down (notconnect)
GigabitEthernet1/2/39 is down, line protocol is down (notconnect)
GigabitEthernet1/2/40 is up, line protocol is up (connected)
GigabitEthernet1/2/41 is up, line protocol is up (connected)
GigabitEthernet1/2/42 is up, line protocol is up (connected)
GigabitEthernet1/2/43 is up, line protocol is up (connected)
GigabitEthernet1/2/44 is up, line protocol is up (connected)
GigabitEthernet1/2/45 is up, line protocol is up (connected)
GigabitEthernet1/2/46 is administratively down, line protocol is down (disabled)
GigabitEthernet1/2/47 is administratively down, line protocol is down (disabled)
GigabitEthernet1/2/48 is up, line protocol is up (connected)
TenGigabitEthernet2/1/1 is up, line protocol is up (connected)
TenGigabitEthernet2/1/2 is up, line protocol is up (connected)
TenGigabitEthernet2/1/3 is administratively down, line protocol is down (disabled)
TenGigabitEthernet2/1/4 is administratively down, line protocol is down (disabled)
GigabitEthernet2/2/1 is up, line protocol is up (connected)
GigabitEthernet2/2/2 is down, line protocol is down (notconnect)
GigabitEthernet2/2/3 is down, line protocol is down (notconnect)
GigabitEthernet2/2/4 is down, line protocol is down (notconnect)
GigabitEthernet2/2/5 is down, line protocol is down (notconnect)
GigabitEthernet2/2/6 is down, line protocol is down (notconnect)
GigabitEthernet2/2/7 is down, line protocol is down (notconnect)
GigabitEthernet2/2/8 is down, line protocol is down (notconnect)
GigabitEthernet2/2/9 is down, line protocol is down (notconnect)
GigabitEthernet2/2/10 is down, line protocol is down (notconnect)
GigabitEthernet2/2/11 is down, line protocol is down (notconnect)
GigabitEthernet2/2/12 is down, line protocol is down (notconnect)
GigabitEthernet2/2/13 is down, line protocol is down (notconnect)
GigabitEthernet2/2/14 is down, line protocol is down (notconnect)
GigabitEthernet2/2/15 is down, line protocol is down (notconnect)
GigabitEthernet2/2/16 is down, line protocol is down (notconnect)
GigabitEthernet2/2/17 is down, line protocol is down (notconnect)
GigabitEthernet2/2/18 is down, line protocol is down (notconnect)
GigabitEthernet2/2/19 is down, line protocol is down (notconnect)
GigabitEthernet2/2/20 is down, line protocol is down (notconnect)
GigabitEthernet2/2/21 is up, line protocol is up (connected)
GigabitEthernet2/2/22 is up, line protocol is up (connected)
GigabitEthernet2/2/23 is down, line protocol is down (notconnect)
GigabitEthernet2/2/24 is down, line protocol is down (notconnect)
GigabitEthernet2/2/25 is down, line protocol is down (notconnect)
GigabitEthernet2/2/26 is down, line protocol is down (notconnect)
GigabitEthernet2/2/27 is down, line protocol is down (notconnect)
GigabitEthernet2/2/28 is down, line protocol is down (notconnect)
GigabitEthernet2/2/29 is down, line protocol is down (notconnect)
GigabitEthernet2/2/30 is down, line protocol is down (notconnect)
GigabitEthernet2/2/31 is down, line protocol is down (notconnect)
GigabitEthernet2/2/32 is down, line protocol is down (notconnect)
GigabitEthernet2/2/33 is down, line protocol is down (notconnect)
GigabitEthernet2/2/34 is down, line protocol is down (notconnect)
GigabitEthernet2/2/35 is down, line protocol is down (notconnect)
GigabitEthernet2/2/36 is down, line protocol is down (notconnect)
GigabitEthernet2/2/37 is down, line protocol is down (notconnect)
GigabitEthernet2/2/38 is down, line protocol is down (notconnect)
GigabitEthernet2/2/39 is up, line protocol is up (connected)
GigabitEthernet2/2/40 is up, line protocol is up (connected)
GigabitEthernet2/2/41 is up, line protocol is up (connected)
GigabitEthernet2/2/42 is up, line protocol is up (connected)
GigabitEthernet2/2/43 is up, line protocol is up (connected)
GigabitEthernet2/2/44 is up, line protocol is up (connected)
GigabitEthernet2/2/45 is up, line protocol is up (connected)
GigabitEthernet2/2/46 is down, line protocol is down (notconnect)
GigabitEthernet2/2/47 is down, line protocol is down (notconnect)
GigabitEthernet2/2/48 is up, line protocol is up (connected)
Port-channel1 is up, line protocol is up (connected)
Port-channel2 is up, line protocol is up (connected)
Port-channel10 is up, line protocol is up (connected)
Port-channel11 is up, line protocol is up (connected)
Port-channel50 is up, line protocol is up (connected)
Port-channel61 is up, line protocol is up (connected)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 352
Port-channel62 is up, line protocol is up (connected)
Port-channel100 is up, line protocol is up (connected)
Vlan1 is down, line protocol is down
Vlan17 is up, line protocol is up
Vlan24 is up, line protocol is up
Vlan35 is up, line protocol is up
Vlan36 is up, line protocol is up
Vlan39 is up, line protocol is up
Vlan40 is up, line protocol is up
Vlan48 is up, line protocol is up
Vlan49 is up, line protocol is up
Vlan215 is up, line protocol is up
Vlan218 is up, line protocol is up
Vlan4050 is up, line protocol is up
Vlan4051 is up, line protocol is up
% Invalid input detected at '^' marker.
sw4501#  show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 136 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 138 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (32768 bytes):
*Apr  3 03:40:41.966: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'entservices'
*Apr  3 03:41:53.785: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 11 port 1.
*Apr  3 03:41:54.286: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 11 port 2.
*Apr  3 03:42:10.293: %VSLP-5-VSL_UP:  Ready for control traffic
*Apr  3 03:42:13.293: %VSLP-5-RRP_ROLE_RESOLVED: Role resolved as STANDBY by VSLP
*Apr  3 03:42:43.294: %C4K_REDUNDANCY-6-INIT: STANDBY:Initializing as STANDBY supervisor
*Apr  3 03:42:52.577: %C4K_REDUNDANCY-6-DUPLEX_MODE: STANDBY:The peer Supervisor has been detected
*Apr  3 03:42:52.637: %C4K_REDUNDANCY-3-COMMUNICATION: STANDBY:Communication with the peer Supervisor has been established
Apr  3 03:43:09.529: mcprp_register_mempools: Failed to get local entity physical index!
Apr  3 03:43:09.529: mcprp_register_bufferpools: Failed to get local entity physical index!
Apr  3 03:43:10.720: %C4K_REDUNDANCY-6-MODE: STANDBY:STANDBY supervisor initializing for sso mode
Apr  3 03:43:11.123: %SPANTREE-5-EXTENDED_SYSID: STANDBY:Extended SysId enabled for type vlan
Apr  3 03:43:11.829: %C4K_IOSMODPORTMAN-6-MODULEONLINE: STANDBY:Module 1 (WS-X45-SUP7-E S/N: CAT1642L4XZ Hw: 2.1) is online
Apr  3 03:43:11.829: %C4K_IOSMODPORTMAN-6-MODULEONLINE: STANDBY:Module 2 (WS-X4748-RJ45-E S/N: CAT1640L47G Hw: 1.1) is online
Apr  3 03:43:11.829: %C4K_IOSMODPORTMAN-6-MODULEONLINE: STANDBY:Module 11 (WS-X45-SUP7-E S/N: CAT1642L4YF Hw: 2.1) is online
Apr  3 03:43:11.829: %C4K_IOSMODPORTMAN-6-MODULEONLINE: STANDBY:Module 12 (WS-X4748-RJ45-E S/N: CAT1640L46Y Hw: 1.1) is online
Apr  3 11:43:19 HKT: %SPANTREE-6-PORTDEL_ALL_VLANS: STANDBY:Port-channel61 deleted from all Vlans
Apr  3 11:43:19 HKT: %SPANTREE-6-PORTDEL_ALL_VLANS: STANDBY:Port-channel62 deleted from all Vlans
Apr  3 11:43:26 HKT: %SYS-5-RESTART: STANDBY:System restarted --
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 05:58 by prod_rel_team
Apr  3 11:43:27 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/1 joined port-channel Po50
Apr  3 11:43:27 HKT: %EC-5-BUNDLE: STANDBY:Interface GigabitEthernet1/2/44 joined port-channel Port-channel2
Apr  3 11:43:27 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/45 joined port-channel Po100
Apr  3 11:43:27 HKT: %EC-5-BUNDLE: STANDBY:Interface GigabitEthernet1/2/48 joined port-channel Port-channel1
Apr  3 11:43:27 HKT: %EC-5-BUNDLE: STANDBY:Interface TenGigabitEthernet1/1/1 joined port-channel Port-channel61
Apr  3 11:43:26 HKT: %EC-5-BUNDLE: STANDBY:Interface TenGigabitEthernet1/1/2 joined port-channel Port-channel61
Apr  3 11:43:30 HKT: %EC-5-BUNDLE: STANDBY:Interface TenGigabitEthernet2/1/1 joined port-channel Port-channel62
Apr  3 11:43:30 HKT: %EC-5-BUNDLE: STANDBY:Interface TenGigabitEthernet2/1/2 joined port-channel Port-channel62
Apr  3 11:43:30 HKT: %EC-5-UNBUNDLE: STANDBY:Interface TenGigabitEthernet2/1/1 left the port-channel Port-channel62
Apr  3 11:43:30 HKT: %EC-5-UNBUNDLE: STANDBY:Interface TenGigabitEthernet2/1/2 left the port-channel Port-channel62
Apr  3 11:43:31 HKT: %EC-5-BUNDLE: STANDBY:Interface TenGigabitEthernet2/1/1 joined port-channel Port-channel62
Apr  3 11:43:32 HKT: %EC-5-BUNDLE: STANDBY:Interface TenGigabitEthernet2/1/2 joined port-channel Port-channel62
Apr  3 11:43:35 HKT: %EC-5-BUNDLE: STANDBY:Interface GigabitEthernet2/2/44 joined port-channel Port-channel1
Apr  3 11:43:35 HKT: %EC-5-BUNDLE: STANDBY:Interface GigabitEthernet2/2/48 joined port-channel Port-channel2
Apr  3 11:43:38 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/45 joined port-channel Po100
Apr  3 11:44:24 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/1 joined port-channel Po50
Apr  4 01:52:04 HKT: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: STANDBY:Keepalive messages from peer Supervisor are missing for 27 seconds
Apr 16 17:56:58 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi2/2/45 left the port-channel Po100
Apr 16 18:00:23 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/45 joined port-channel Po100
Apr 16 18:01:07 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi1/2/45 left the port-channel Po100
Apr 16 18:03:31 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/45 joined port-channel Po100
Apr 29 09:32:06 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/41 joined port-channel Po10
Apr 29 09:32:59 HKT: %EC-5-CANNOT_BUNDLE2: STANDBY:Gi2/2/41 is not compatible with Gi1/2/41 and will be suspended (trunk mode of Gi2/2/41 is access, Gi1/2/41 is trunk)
Apr 29 09:34:38 HKT: %EC-5-CANNOT_BUNDLE2: STANDBY:Gi2/2/41 is not compatible with Gi1/2/41 and will be suspended (trunk mode of Gi2/2/41 is access, Gi1/2/41 is trunk)
Apr 29 09:35:17 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/41 joined port-channel Po10
Apr 29 09:39:57 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/43 joined port-channel Po11
Apr 29 09:39:57 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/43 joined port-channel Po11
Apr 29 09:40:18 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi1/2/43 left the port-channel Po11
Apr 29 09:40:18 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi2/2/43 left the port-channel Po11
Apr 29 09:40:24 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/43 joined port-channel Po11
Apr 29 09:40:25 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/43 joined port-channel Po11
May  2 10:53:47 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi1/2/43 left the port-channel Po11
May  2 10:53:47 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi2/2/43 left the port-channel Po11
May  2 10:54:00 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/43 joined port-channel Po11
May  2 10:59:43 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi1/2/41 left the port-channel Po10
May  2 10:59:43 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi2/2/41 left the port-channel Po10
May  2 11:27:51 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/41 joined port-channel Po10
May  2 11:27:55 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/41 joined port-channel Po10
May  2 11:53:47 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi2/2/43 left the port-channel Po11
May  2 12:00:01 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/43 joined port-channel Po11
May  2 12:00:04 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi2/2/43 joined port-channel Po11
Jun 15 19:15:53 HKT: %EC-5-UNBUNDLE: STANDBY:Interface Gi1/2/45 left the port-channel Po100
Jun 15 19:16:04 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/45 joined port-channel Po100
Jun 25 22:04:10 HKT: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
Jun 25 22:04:10 HKT: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been lost
Jun 25 22:04:10 HKT: %C4K_REDUNDANCY-3-SIMPLEX_MODE: The peer Supervisor has been lost
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface TenGigabitEthernet2/1/2 left the port-channel Port-channel62
Jun 25 22:04:10 HKT: %VSLP-3-VSLP_LMP_FAIL_REASON: Te2/1/2: Link down
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface TenGigabitEthernet2/1/1 left the port-channel Port-channel62
Jun 25 22:04:10 HKT: %VSLP-3-VSLP_LMP_FAIL_REASON: Te2/1/1: Link down
Jun 25 22:04:10 HKT: %VSLP-2-VSL_DOWN:   All VSL links went down while switch is in Standby role
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1/1 left the port-channel Port-channel61
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1/2 left the port-channel Port-channel61
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface Gi1/2/1 left the port-channel Po50
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface Gi1/2/41 left the port-channel Po10
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface Gi1/2/43 left the port-channel Po11
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface GigabitEthernet1/2/44 left the port-channel Port-channel2
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface Gi1/2/45 left the port-channel Po100
Jun 25 22:04:10 HKT: %EC-5-UNBUNDLE: Interface GigabitEthernet1/2/48 left the port-channel Port-channel1
Jun 25 22:04:12 HKT: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/39, changed state to up
Jun 25 22:04:13 HKT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/2/39, changed state to up
Jun 25 22:04:41 HKT: %OSPF-5-ADJCHG: Process 1, Nbr 203.198.7.182 on Vlan40 from LOADING to FULL, Loading Done
Jun 25 22:04:53 HKT: %OSPF-5-ADJCHG: Process 1, Nbr 218.102.33.25 on Vlan49 from LOADING to FULL, Loading Done
Jun 25 22:04:53 HKT: %OSPF-5-ADJCHG: Process 1, Nbr 203.198.7.181 on Vlan39 from LOADING to FULL, Loading Done
Jun 25 22:09:44 HKT: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 11 port 1.
Jun 25 22:09:45 HKT: %C4K_IOSINTF-5-LMPHWSESSIONSTATE: Lmp HW session UP on slot 11 port 2.
Jun 25 22:10:00 HKT: %VSLP-5-VSL_UP:  Ready for control traffic
Jun 25 22:10:04 HKT: %VSLP-5-RRP_ROLE_RESOLVED: Role resolved as ACTIVE  by VSLP
Jun 25 22:10:04 HKT: %EC-5-BUNDLE: Interface TenGigabitEthernet2/1/1 joined port-channel Port-channel62
Jun 25 22:10:04 HKT: %EC-5-BUNDLE: Interface TenGigabitEthernet2/1/2 joined port-channel Port-channel62
Jun 25 22:10:04 HKT: %C4K_REDUNDANCY-6-DUPLEX_MODE: The peer Supervisor has been detected
Jun 25 22:11:11 HKT: %C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for sso mode
Jun 25 22:11:12 HKT: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been established
Jun 25 22:11:22 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successfully synchronized to the standby supervisor
Jun 25 22:11:22 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been successfully synchronized to the standby supervisor
Jun 25 22:11:22 HKT: %C4K_REDUNDANCY-5-CALENDAR: The calendar has been successfully synchronized to the standby supervisor for the first time
Jun 25 22:11:22 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
Jun 25 22:11:23 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
Jun 25 22:11:25 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database has been successfully synchronized to the standby supervisor
Jun 25 22:11:58 HKT: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/1 joined port-channel Port-channel61
Jun 25 22:11:58 HKT: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/2 joined port-channel Port-channel61
Jun 25 22:11:59 HKT: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1/1 left the port-channel Port-channel61
Jun 25 22:11:59 HKT: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1/2 left the port-channel Port-channel61
Jun 25 22:12:00 HKT: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/1 joined port-channel Port-channel61
Jun 25 22:12:00 HKT: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/2 joined port-channel Port-channel61
Jun 25 22:12:01 HKT: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Jun 25 22:12:02 HKT: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Jun 25 22:12:04 HKT: %EC-5-BUNDLE: Interface GigabitEthernet1/2/48 joined port-channel Port-channel1
Jun 25 22:12:04 HKT: %EC-5-BUNDLE: Interface GigabitEthernet1/2/44 joined port-channel Port-channel2
Jun 25 22:12:05 HKT: %EC-5-BUNDLE: Interface Gi1/2/1 joined port-channel Po50
Jun 25 22:12:04 HKT: %EC-5-BUNDLE: STANDBY:Interface GigabitEthernet1/2/48 joined port-channel Port-channel1
Jun 25 22:12:04 HKT: %EC-5-BUNDLE: STANDBY:Interface GigabitEthernet1/2/44 joined port-channel Port-channel2
Jun 25 22:12:07 HKT: %EC-5-BUNDLE: Interface Gi1/2/41 joined port-channel Po10
Jun 25 22:12:07 HKT: %EC-5-BUNDLE: Interface Gi1/2/43 joined port-channel Po11
Jun 25 22:12:07 HKT: %EC-5-BUNDLE: Interface Gi1/2/45 joined port-channel Po100
Jun 25 22:12:07 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/41 joined port-channel Po10
Jun 25 22:12:07 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/43 joined port-channel Po11
Jun 25 22:12:07 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/45 joined port-channel Po100
Jun 25 22:12:22 HKT: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=3: Transceiver has been inserted
Jun 25 22:12:23 HKT: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=4: Transceiver has been inserted
Jun 25 22:12:44 HKT: %EC-5-BUNDLE: STANDBY:Interface Gi1/2/1 joined port-channel Po50
Jun 26 09:08:38 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
Jun 26 09:08:39 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
Jun 26 11:12:07 HKT: %SYS-5-CONFIG_I: Configured from console by wnyuen on vty1 (192.168.133.8)
Jun 27 22:36:46 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
Jun 27 22:36:47 HKT: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
Can you please try clearing the mac address table and update me the result.
I will give a explanation for that later if you want after getting to know the status .
Inayath
Hi Inayath
The CPU utlization back to normal after clear the mac table. Appercite if you could share your view.
Core 0: CPU utilization for five seconds: 2%; one minute: 3%;  five minutes: 3%
Core 1: CPU utilization for five seconds: 7%; one minute: 7%;  five minutes: 9%
8509   3617978     18657802 200    5.00     5.11     6.17     0     iosd
6068   1359366     18944179 7      0.04     0.02     0.01     0     pdsd
11862  2111454     19191559 55     0.04     0.06     0.07     0     ffm
BR
Yuen,
1)   the high cpu was due to SA Miss
SA Miss is populated when the source MAC is unknown for the packet so it is
sent to the CPU for mac learning.SA Miss generally is due to extensive mac
tcam being utilized utilized. But in our case the MAT was hardly utilized.
Did not observe any mac-flap . No STP changes was observed.
2)  along with SA miss we also see a lot of and "Vs Tunnel Data Pkt"
continuously incrementing
{Vs Tunnel Data Pkt          1913749950     15569     16162     13467      12827}
3)  After decoding the above packets the original packets were ASIC Sa Miss
packets on the standby which were tunneled from standby to active as Vs
Tunnel Data Pkt. This is the reason we were observing the "Vs Tunnel Data
Pkt" increment. The ASIC Sa Miss on the standby would cause SA-Miss on the
active.
When we say asic SA-Miss we mean that the src mac is not present in the hw
mac address table on the standby. The same mac address is present in the
software as well as hardware on the active.
The reason why we were seeing high cpu on the active sup was the fact that
the platform programming on active and standby (at least, at the single
point-in-time it was captured) that the original source MAC addresses on the
packets being tunneled to the VSS active are seen in the HW programming on
the active but not standby.  This is a potential cause for a persistent
learning state, which would be remedied by a dynamic MAC table clear
(assuming the problem didn't immediate occur again).
4) In our case we did not get the chance to clear the mac table as the cpu
dropped down and the issue got cleared on its own before we checked anything
further on the standby.
Inayath
*Plz rate all usefull posts and mark this thread as answered so that others may get benefited.
Yuen,
Is there anything else I can help you with on this ? Else can you mark this thread as answered please rather than leaving it as unanswered.
thanks in advance.
Inayath
Hi Inayath,
The high CPU gone after clearing the mac table. Tks.
The exact problem of the pair of 4500 running VSS was can't remote access few days ago. The traffic passed through the switch and  the routing seem fine ( OSPF is estalished), However, ping from the direct connected subnet OSPF neighbour no response. We tried switch over the sup and problem gone but triggered high CPU after the Sup switchover, we open a TAC case already and awaiting the Cisco response
