3570-SFP module
bapatsubodh
Level 7
Level 7
Cisco WS-C3750G-12S at remote location. And the output of show interface is as follows:
sh int gigabitEthernet 1/0/4
GigabitEthernet1/0/4 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0019.55be.1b04 (bia 0019.55be.1b04)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP ------------> (Is SFP module installed in this interface port?)
  Media-type configured as  connector
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicast)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
Can we know from this output that the interface Gigabit 1/0/4 has been populated by SFP module? (1000BaseSX SFP) or it's just an empty slot that can accomodate the SFP module?
Please share the experience.
Cheers!
Subodh
2 Accepted Solutions
fb_webuser
Level 11
Level 11
yes, otherwise it will be "media type is Not Present" in the event SFP module is not inserted.
Posted by WebUser Neeraj Jagga from Cisco Support Community App
darren.g
Level 10
Level 10
Cheers!
Subodh
Yes.
If there was no SFP in the port, it would look like this
sh int g1/1/2
GigabitEthernet1/1/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 4055.39de.d532 (bia 4055.39de.d532)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is Not Present
[...snipt for brevity...]
Notice the "media type is Not Present"
Cheers.
fb_webuser
Level 11
Level 11
darren.g
Level 10
Level 10
Cheers!
Subodh
Yes.
sh int g1/1/2
  Keepalive not set
Cheers.
