Total OUTPUT errors are increasing
pcclonescisco
Community Member
--Port changed
--Cable Changed
--Switch Changed
          --Still i am getting total output errors increasing. Please find the output :
Switch_C2960#show mls qos maps cos-output-q
   Cos-outputq-threshold map:
              cos:  0   1   2   3   4   5   6   7
  queue-threshold: 2-1 2-1 3-1 3-1 4-1 1-1 4-1 4-1
Switch_C2960#
Switch_C2960#show int gi 0/2 | i drop
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6730674
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6744503
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6750775
Switch_C2960#
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0064.40e2.049a (bia 0064.40e2.049a)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 120/255, rxload 119/255
  Keepalive not set
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:19:05
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6861499
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 46696000 bits/sec, 30735 packets/sec
  5 minute output rate 47231000 bits/sec, 30942 packets/sec
     34276803 packets input, 6544806578 bytes, 0 no buffer
     Received 115 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     34512247 packets output, 6621715081 bytes, 0 underruns
Switch_C2960#
Switch_C2960#show run int gi 0/2
Building configuration...
Current configuration : 88 bytes
interface GigabitEthernet0/2
switchport access vlan 835
switchport mode access
end
Switch_C2960#
Switch_C2960#show platform port-asic stats drop port 0
Port-asic Port Drop Statistics - Summary
  RxQueue 0 Drop Stats: 0
  RxQueue 1 Drop Stats: 0
  RxQueue 2 Drop Stats: 0
  RxQueue 3 Drop Stats: 0
  Port  0 TxQueue Drop Stats: 63277066
  Port  1 TxQueue Drop Stats: 0
  Port  2 TxQueue Drop Stats: 49383178
  Port  3 TxQueue Drop Stats: 51758832
  Port  4 TxQueue Drop Stats: 9275671
  Port  5 TxQueue Drop Stats: 53647146
  Port  6 TxQueue Drop Stats: 53858100
  Port  7 TxQueue Drop Stats: 53857557
  Port  8 TxQueue Drop Stats: 159897632
  Port  9 TxQueue Drop Stats: 8246366
  Port 10 TxQueue Drop Stats: 8246193
  Port 11 TxQueue Drop Stats: 0
  Port 12 TxQueue Drop Stats: 0
  Port 13 TxQueue Drop Stats: 207
  Port 14 TxQueue Drop Stats: 46213276
  Port 15 TxQueue Drop Stats: 264923216
  Port 16 TxQueue Drop Stats: 53862249
  Port 17 TxQueue Drop Stats: 51784865
  Port 18 TxQueue Drop Stats: 53894071
  Port 19 TxQueue Drop Stats: 126518775
  Port 20 TxQueue Drop Stats: 0
  Port 21 TxQueue Drop Stats: 0
  Port 22 TxQueue Drop Stats: 0
  Port 23 TxQueue Drop Stats: 3349011
  Port 24 TxQueue Drop Stats: 146400088
  Port 25 TxQueue Drop Stats: 54561450
  Supervisor TxQueue Drop Statistics
    Queue  0: 0
    Queue  1: 0
    Queue  2: 0
    Queue  3: 137
    Queue  4: 0
    Queue  5: 0
    Queue  6: 0
    Queue  7: 0
    Queue  8: 11120745
    Queue  9: 0
    Queue 10: 0
    Queue 11: 0
    Queue 12: 0
    Queue 13: 0
    Queue 14: 0
    Queue 15: 0
Port-asic Port Drop Statistics - Details
  RxQueue Drop Statistics
    Queue 0
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 1
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 2
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 3
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
  Port 0 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 63290911
      Weight 1 Frames 1
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue  0: 0
    Queue  1: 0
    Queue  2: 0
    Queue  3: 137
    Queue  4: 0
    Queue  5: 0
    Queue  6: 0
    Queue  7: 0
    Queue  8: 11120745
    Queue  9: 0
    Queue 10: 0
    Queue 11: 0
    Queue 12: 0
    Queue 13: 0
    Queue 14: 0
    Queue 15: 0
Switch_C2960#
6 Replies 6
smehrnia
Level 11
Level 11
hello,
try a different qos / queueing method.
this Links might help:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
its Bcoz of ur traffic pattern n flows.
plz Rate if it helped
Hope it Helps!
Soroush.
one more finding..
when i connect a laptop on the same port, i dont see any output drops increasing..only if i connect a firewall, the output drops are increasing.
do u still want me to try queueuing method ?
paolo bevilacqua
Remove all and any QoS or  mls commands. That for one will make the switch work the best.
However note that the interface is running 100 Mbps.If you want to avoid drops. run it at 1Gbps.
Can you try changing hold-queue limit to maximum if your switch support it ?
Command under interface level is:
hold-queue 4096 in
hold-queue 4096 out
Regards # Mahesh
smehrnia
Level 11
Level 11
Of course, a firewall (if its active) would generate more traffic than a laptop to cause drops... so what u need is to try different things to figure out what solves the problem 😉 u r at the scene, we r just speculating
Hope it Helps!
Soroush.
pcclonescisco
Community Member
unable to disable mls qos on the switch:
QoS is enabled
QoS ip packet dscp rewrite is enabled
Switch_C2960#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch_C2960(config)#mls qos ?
  aggregate-policer  Named aggregate policer
  map                qos map keyword
  queue-set          Choose a queue set for this queue
  rewrite            Rewrite Packet/Frame
  srr-queue          Configure SRR receive queues
----Other end wont support 1Gig and the traffic is not crossing more than 60Mbps
----About the Hold-queue:
Caution: An increase in the hold queue can have detrimental effects on network routing and response times. For protocols that use SEQ/ACK packets to determine round-trip times, do not increase the output queue. Dropping packets instead informs hosts to slow down transmissions to match available bandwidth. This is generally better than duplicate copies of the same packet within the network, which can happen with large hold queues.
So i need to get a down time to increase the hold queue.
