3650-24TS interface numbering
Hi all,
Very basic question but essential for me (since I don't have the hardware in front of me).
Can someone tell the interface numbering on a 3560-24TS (the copper ports).
The front panel doesn't give me any clue whether the interface n°0 is the up or the bottom interface 😞
There is a indication "01X" but I'm not 100% sure if the n°0 should be the top one.
Thanks!
you can see numbering at below raw of ports. eg. '01X' means port number 1. its near '^' light. that means 1st port is top row 1st port. then next light indicate second port. it marked towards down. so second port is port below the 1st port.
1  3  5
2  4  6   etc.
this is the numbering patern
Good luck
KB
jaton
Level 2
Level 2
The cisco switches are numbert
1 3 5 7 9   11
2 4 6 8 10 12
This is a guide for the installation:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/hardware/installation/guide/3560hig.pdf
1  3  5
2  4  6   etc.
Good luck
KB
Hi Kasun and Jaton,
Thanks for your replies!
Bye
