nexus 6000 : error tcam region full
apasat
Hi ,
i get Error tcam region full :  when I want to add access-list or access-list on interface vlan
After addding a new  profile tcam resource template i get the same error, even if my new template is commited
Does someone had the same error and how did he resolved it?
I was OUT and use my cellphone so Now I return to home,
@balaji.bandi  already share you the link I attach below and I see you config template BUT BUT
template you config is same as default
Template Type State Vacl Ifacl Rbacl Qos Span Sup TOTAL
default system Created 1024 1152 1152 448 64 256 4096
test1 user Committed   1024 1152 1152 448 64 256 4096
here you have TCAM location for VACL RbACL IfACL we don't know your config but you can increase the Rbacl (since your ACL is config under SVI, for more info. please see attachment) and decrease one of other  allocation in final you must get total sum 4096
the command you can use
switch(config-tmpl)#
{vacl vacl-region | ifacl ifacl-region | qos qos-region | rbacl rbacl-region | span span-region}
11 Replies 11
balaji.bandi
what nexus code running :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus6000/sw/security/6x/b_6k_Security_Config_6x/b_6k_Security_Config_6x_chapter_01110.html
can you post some information related to config and output show in the document to verify.
BB
i created this template using the guide that you send .
test1 is a new template created by myself
ok after creating the template, is the issue still persists ?
BB
yes
thanks, i will change these parameters and see the result, come back with feedback
https://www.cisco.com/c/en/us/support/docs/switches/nexus-9000-series-switches/119032-nexus9k-tcam-00.html
pleas read this doc. carefully, there is way to free some bytes in TCAM by assign "0" for some ACL.
please read it carefully.
my switch doesn't recognise all commads from this guide
marce1000
                    - FYI https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu59317
 M.
 Nexus 5672UP 16G-FC , System version: 7.3(9)N1(1
problems in this version as well
