3650 and 3750-X Series Switches
nshoe18
Does anyone know if the new 3560 and 3750-X series switchs include crypto as part of the image or is there a seperate image to be used for crypto as in the older switches?
Thanks in advance.
The switch models are available with either the LAN Base or IP Base feature set. IP Services feature set is available as an upgrade option at the time of ordering or through a license at a later time.
And Crypto is part of the IP Base
Please click on the correct answer if this answered your question.
Naidu.
Antonio Knox
Level 7
Level 7
The 3560 and 3750-X ship with either LAN BASE or IP BASE.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
Message was edited by: Antonio Knox
I got that Antonio, I am trying to figure out if there is a Crypto image for them. Or is Crypto part of the IP Base or LAN Base.
Naidu.
Thank you. That is what I was looking for.
