3650 booting up on switch: mode only
CSCO10917823
This switch was part of a stock of two switches. one day this switch failed and start rebooting I quickly remove the switch and replace it with a new one.
Now am trying to recover this switch.
Some of what I have tried
1.   copy the .bin file to a USB flash drive.
2.
emergency-install usbflash0:/cat3k_caa-universalk9.16.09.06.SPA.bin
emergency-install flash:cat3k_caa-universalk9.16.09.06.SPA.bin
boot usbflash0:/cat3k_caa-universalk9.16.09.06.SPA.bin
I have also change the manual_boot to no
get the same result.
Am not 100% sure but I believe the problem is in the Packages.conf but down know what to change.
*Sep 7 13:40:58.187: %SNMP-5-COLDSTART: SNMP agent on host 3650-FriarsHill.219 is undergoing a cold start
*Sep 7 13:40:58.671: %PMAN-5-EXITACTION: Switch 1 R0/0: pvp: Process manager is exiting: reload fp action requested
*Sep 7 13:41:00.390: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2601090854.server has been generated or imported by crypto-engine
*Sep 7 13:41:02.912: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)Switch rebooted continously for atleast 5 times. Disabling autoreboot
Sep 7 13:41:13.797: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: rp processes exit with reload switch code
Sep 7 13:41:20.617: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/system-report_1_20210907-134116-Universal.tar.gz (size: 3357 KB) generated. Where can i find this file?
reboot: Restarting system
switch: set
ABNORMAL_RESET_COUNT=0
ASIC_PCI_RESET=1
AUTOREBOOT_RESTORE=1
BOOT=flash:packages.conf
BOOT_LOADER_UPGRADE_DISABLE=1
BSI=0
CFG_MODEL_NUM=WS-C3650-24PDM-S
CLEI_CODE_NUMBER=INM2F00ARA
CSR_PCIERST_DISCONNECTED=yes
DC_COPY=yes
DDR_SPEED=667
ECI_CODE_NUMBER=471204
IP_ADDR=192.168.1.11/24
LICENSE_BOOT_LEVEL=ipbasek9,all:C3650_24;
MAC_ADDR=C4:F7:D5:5A:38:80
MANUAL_BOOT=yes
MODEL_REVISION_NUM=E0
MOTHERBOARD_ASSEMBLY_NUM=73-17735-04
MOTHERBOARD_REVISION_NUM=B0
MOTHERBOARD_SERIAL_NUM=FDO232506C7
POE1_ASSEMBLY_NUM=73-16439-02
POE1_REVISION_NUM=A0
POE1_SERIAL_NUM=FDO23241QH0
RANDOM_NUM=1998252799
RET_2_RTS=00:28:37 AST Wed Dec 2 2020
SBC_CFG=TheonCSR_24PortSKU_SBC_Config_V1.txt
SWITCH_NUMBER=1
SYSTEM_SERIAL_NUM=FDO2326V063
TAN_NUM=68-100561-02
TAN_REVISION_NUMBER=G0
TEMPLATE=advanced
TERMLINES=0
USB_ASSEMBLY_NUM=73-16576-01
USB_REVISION_NUM=A0
USB_SERIAL_NUM=FDO23241V17
VERSION_ID=V02
Directory of usbflash0:/
1 drw- 0 .fseventsd
3 drw- 0 .Spotlight-V100
72 -rw- 450568480 cat3k_caa-universalk9.16.09.06.SPA.bin
73 -rw- 4096 ._cat3k_caa-universalk9.16.09.06.SPA.bin
74 -rw- 3339 package.conf
75 -rw- 0 .TemporaryItems
76 drw- 0 .Trashes
81 -rw- 4096 ._package.conf
82 -rw- 4096 tech_support
83 -rw- 2097152 nvram_config
84 -rw- 4096 ._nvram_config
85 -rw- 916 vlan.dat
15001657344 bytes available (453918720 bytes used)
switch: dir flash:
Directory of flash:/
144577 drwx 4096 .
2 drwx 4096 ..
144578 -rw- 2097152 nvram_config
144579 -rw- 2097152 nvram_config_bkup
144580 -rw- 19862144 cat3k_caa-guestshell.16.09.06.SPA.pkg
144581 -rw- 30872219 cat3k_caa-rpbase.16.09.06.SPA.pkg
144582 -rw- 373863032 cat3k_caa-rpcore.16.09.06.SPA.pkg
144583 -rw- 3156608 cat3k_caa-srdriver.16.09.06.SPA.pkg
144584 -rw- 22809212 cat3k_caa-webui.16.09.06.SPA.pkg
144585 -rw- 3921 packages.conf
176705 drwx 4096 .installer
144586 -rw- 222 bootloader_evt_handle.log
184737 drwx 4096 core
192769 drwx 4096 .prst_sync
8033 drwx 4096 .rollback_timer
16065 drwx 4096 gs_script
24097 drwx 4096 tech_support
24116 drwx 4096 dc_profile_dir
144587 -rw- 76 boothelper.log
144588 -rw- 123888 memleak.tcl
184739 drwx 4096 .dbpersist
192771 drwx 4096 onep
144589 -rw- 916 vlan.dat
144590 -rw- 0 rdope_out.txt
2903506944 bytes available (516399104 bytes used)
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
flash[18]: (read-only)
usbflash0[19]: (read-write)
tftp[20]: (read-write)
ftp[21]: (read-only)
http[22]: (read-only)
Any assistance is greatly appreciated.
Leo Laohoo
@CSCO10917823 wrote:
MANUAL_BOOT=yes
Manual Boot is still set to "yes".  Try this command:  MANUAL_BOOT=no
Thanks Leo.
That was change back to yes during the emergency-install install.
This is the new packages.conf
switch: set MANUAL_BOOT no
switch: set
ASIC_PCI_RESET=1
BSI=0
DC_COPY=yes
DDR_SPEED=667
MANUAL_BOOT=no
SWITCH_NUMBER=1
TEMPLATE=advanced
TERMLINES=0
USB_REVISION_NUM=A0
VERSION_ID=V02
boot=flash:cat3k_caa-rpcore.16.09.06.SPA.pkg How can I delete this line and is the system using it during boot up
unset boot
