08-13-2019 06:06 PM
Got 2 x WS-C3650-24TS from the service provider, when I boot up it comes up with, 1 one of them works fine the other one comes up with below, can you please advise how to install
IOS I want to install "03.06.08E" "cat3k_caa-universalk9"
switch:
dir flash:
Directory of flash:/
61953 drwx 4096 .
2 drwx 4096 ..
61954 -rw- 2097152 nvram_config
61974 -rw- 43109956 cat3k_caa-iosd-universalk9.SPA.152-2.E8.pkg
61978 -rw- 1237 cat3k_caa-universalk9.SPA.03.06.08.E.152-2.E8.conf
1317650432 bytes available (330244096 bytes used)
08-13-2019 06:23 PM
Have a look at this post
https://community.cisco.com/t5/switching/switch-startup-mode/td-p/1997038
08-13-2019 07:09 PM
It didn't work for me, getting below error after doing the boot command:
switch: boot flash: cat3k_caa-universalk9.SPA.03.06.08.E.152-2.E8.conf
loading flash:
Reading full image into memory....done
LE hdr->offset=0x800f6478
BE hdr->offset=0x800f6478
MAGIC: 0x322e5350
kernel_image[0]=
kernel_image[1]=ernel_image[2]=
kernel_image[3]=
package_len=4096, offset=738205953, iso_size=-738201857
Image validated
octeon_loadlinux: bad ELF image
Error loading kernel image
usage: boot [<filename>] [<cmdline>]
08-13-2019 08:34 PM
Hi @batishm ,
On the switch that works fine, run the show flash: command.
If in his flash has an .bin file, you can copy that file to the flash of the switch that starts in switch:
You can copy the .bin file to a TFTP server.
Then, copy that file from the TFTP to the other switch.
08-13-2019 08:43 PM
08-14-2019 09:51 AM
Can you try loading this and test?
