3650 Can't route between VLANs
gary.walvin11
We have a brand new 3650 license with IPBase with the following config. Put and laptop into VLAN 2 and another into VLAN 3 using their respective default gateways, disabled firewalls, etc but we can't ping between the VLANs. We've done everything the same was as we have on our 3560 but can't get it to work.
Any suggestions at all please?
Building configuration...
Current configuration : 4635 bytes
! Last configuration change at 09:30:26 UTC Mon Nov 23 2015
version 15.0
no service pad
service compress-config
hostname XXXXXXX
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging console emergencies
enable password admin
username xxxx privilege 15 password 0 xxxxx
username xxxx password 0 xxxxxx
no aaa new-model
switch 1 provision ws-c3650-24ts
ip routing
ip domain-name domain.com
ip device tracking
crypto pki trustpoint TP-self-signed-2717516725
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2717516725
revocation-check none
rsakeypair TP-self-signed-2717516725
crypto pki certificate chain TP-self-signed-2717516725
certificate self-signed 01
quit
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
redundancy
mode sso
class-map match-any non-client-nrt-class
match non-client-nrt
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
switchport access vlan 3
switchport mode access
switchport nonegotiate
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
switchport access vlan 2
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.5.2.2 255.255.255.0
interface Vlan3
ip address 10.5.3.2 255.255.255.0
ip http server
ip http authentication local
ip http secure-server
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
line vty 5 15
login local
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
SW01#
7 Replies 7
Hello
Title =2950 Vsant route between VLANS
Can you please confirm what model you are using - 3650 switch with Ip base feature set should allow inter-vlan routing
Do you have the L2 vlans created?
config t
Vlan2,3
exit
Kind Regards
Paul
Sorry about that, it's a 3650. Title corrected.
Hello
Ip base should work - do you have the clients in the correct vlans with the correct subnets and default-gateways
Are the L2 vlans created?
res
paul
Kind Regards
Paul
swasthik_ms87
Checking L2 Vlan would be a great starting point.
Could you also share me a show ip route output please ? Also check the subnet Mask is matching on machines & Switch Vlan SVI's. Thanks
Ganesh Hariharan
what is the show ip int brief output ? Is all vlan are up and up.
what is the output of show vlan brief ?
Can try removing all config from your interface
and let us know the result.
Hope it Helps..
-GI
gary.walvin1
Thanks for input and sorry for the slow response. We'll investigate some more and report back.
As you investigate it would be helpful if your would post the output of show vlan and of show interface status.
Rick
Rick
