3650 firmware upgrade problem
mediaworksnz
Hello I am trying to upgrade my stack of 5 x 3650 switches.
I am getting flash space free errors. How would you interpret the following logs.
Do they mean that I am lacking free space on switches 2-5 ? - therefore I need to manually free up space on those 4 switches ? Because before I ran the upgrade command it seemed that I had enough space in flash - but perhaps that was only referring to the primary switch in the stack ?
Switch#dir flash:
Directory of flash:/
77602 -rw- 82665136 Dec 5 2016 08:44:44 +00:00 cat3k_caa-base.SPA.03.06.04.E.pkg
77603 -rw- 4913852 Dec 5 2016 08:44:45 +00:00 cat3k_caa-drivers.SPA.03.06.04.E.pkg
77604 -rw- 33784816 Dec 5 2016 08:44:44 +00:00 cat3k_caa-infra.SPA.03.06.04.E.pkg
77605 -rw- 43021636 Dec 5 2016 08:44:45 +00:00 cat3k_caa-iosd-universalk9.SPA.152-2.E4.pkg
77606 -rw- 27417488 Dec 5 2016 08:44:44 +00:00 cat3k_caa-platform.SPA.03.06.04.E.pkg
77608 -rw- 1244 Dec 5 2016 08:44:59 +00:00 packages.conf
11 drwx 4096 Dec 5 2016 08:49:57 +00:00 dc_profile_dir
77609 -rw- 2097152 Nov 8 2018 01:06:11 +00:00 nvram_config
77610 -rw- 556 Nov 8 2018 01:09:07 +00:00 vlan.dat
77611 -rw- 537577577 Nov 8 2018 01:20:40 +00:00 cat3k_caa-universalk9.16.03.06.SPA.bin
1624104960 bytes total (777924608 bytes free)
Switch#$ flash:cat3k_caa-universalk9.16.03.06.SPA.bin switch 1-5 new force
Preparing install operation ...
[1]: Copying software from active switch 1 to switches 2,3,4,5
[1]: Finished copying software to switches 2,3,4,5
[1 2 3 4 5]: Starting install operation
[1 2 3 4 5]: Expanding bundle flash:cat3k_caa-universalk9.16.03.06.SPA.bin
[1 2 3 4 5]: Copying package files
[1 2 3 4 5]: Package files copied
[1 2 3 4 5]: Finished expanding bundle flash:cat3k_caa-universalk9.16.03.06.SPA.bin
[1 2 3 4 5]: Verifying and copying expanded package files to flash:
[2]: % flash: requires 524975 KB of free space, but only 234148 KB is available. Operation aborted.
[3]: % flash: requires 524975 KB of free space, but only 234152 KB is available. Operation aborted.
[4]: % flash: requires 524975 KB of free space, but only 234152 KB is available. Operation aborted.
[5]: % flash: requires 524975 KB of free space, but only 234152 KB is available. Operation aborted.
[1]: % Failed to create candidate tree. Operation aborted.
[2]: % An internal error was encountered. Operation aborted.
[3]: % An internal error was encountered. Operation aborted.
[4]: % An internal error was encountered. Operation aborted.
[5]: % An internal error was encountered. Operation aborted.
[1]: % An internal error was encountered. Operation aborted.
johnd2310
Level 8
Level 8
You will need to free some space on all the switches. Try the following command:
"software clean switch 1-5"
Then try the upgrade again
thanks
John
**Please rate posts you find helpful**
I have same problem. And i try to use software clean command, but it did not help.
