3560CX SFP GLC modules
Hi All,
I'm having a hard time to bring up my GLC-T (3rd party) modules with 3560CX compact switches. I tried with SFP-GE-T module as well. Every time when I pulg it says "  %PHY-4-SFP_NOT_SUPPORTED: The SFP in Gi0/16 is not supported"
I enabled following commands as well. but no use, expect port stop goes to err-disable mode.
no errdisable detect cause gbic-invalid
service internal
service unsupported-transceiver
Am I missing somthing or 3560cx doesn't support at all?
Thanks in advance.
7 Replies 7
omejia
Could you please add the version and the model of the 3560 switch?
Regards.
- Omar
didierdebrouwer
Hello;
GLC-T is not supported on this switch (3rd party or Cisco) ->
supported modules:
Catalyst 3560 CX Series
WS-C3560CX-8PC-S
WS-C3560CX-8TC-S
WS-C3560CX-12TC-S
WS-C3560CX-12PC-S
WS-C3560CX-12PD-S
WS-C3560CX-8XPD-S
GLC-BX-D
GLC-BX-U
GLC-GE-100FX
GLC-LH-SMD
GLC-SX-MMD
GLC-EX-SMD
GLC-ZX-SMD
GLC-ZX-SM
GLC-LH-SM
GLC-SX-MM
DWDM SFP
CWDM SFP
15.2(3)E
15.2(3)E
Source
Regards;
D
permejdal
GLC-T modules will be supported for 2960CX and 3560CX from version 15.2(5)E.
Hmm. I have to put the new ios and see how it goes. But, Cisco document says hardware itself its not going to support due to GLC-T need more power than a normal SFP. Unless Cisco has really changed hardware infrastructure  I highly doubt its  going to work.
Do you have any supporting document saying its going to support on version 15.2. (5)E?
Thili
I have 2960CX and 3560CX switches, where I have installed 15.2(5)E, and I can confirm that they now work with GLC-T modules.
Normally the thermal limitations of the switch is 45°C. But when using GLC-T SFP modules, it is between 20 and 35°C depending of the physical installation (read source).
HI, do you know if the 3560CX works with GLC-TE? In the compatiblity matrix it is not clear to me.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc487104941
Thanks in advance.
Jorge
Mancunian
Features Introduced in Cisco IOS Release 15.2(5)E
GLC-T SFP Module Support—The switches can now be used with GLC-T SFP module. For more details on the Operating temperature limitations, please refer the Catalyst 3560-CX and 2960-CX Switch Hardware Installation Guide on cisco.com
