[3650 maximum HSRP groups]
Carlos A. Silva
Level 7
Level 7
Is there a maximum of HSRP instances in a 3650 like there used to be in a 3560?
Can't find any trace of this in the configuration guide?
Thanks!
c.
Reza Sharifi
The range for HSRP groups is 0-255
  • (Optional) group-number- The group number on the interface for which HSRP is being enabled. The range is 0 to 255; the default is 0. If there is only one HSRP group, you do not need to enter a group number.
Link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3e/ip/configuration_guide/b_ip_fhrp_3e_3650_cg/b_fhrp_3se_3650_cg_chapter_01.html
Hi, Reza:
Thanks for your reply, but if you look at the 3560 config guide it says the same but describes a limit of 32 instances of HSRP.
So, you can use numbers between 0-255, but only for 32 total “groupings”. While you are correct, what I’d like to know is if there is such a limit of grouping like in the 3560.
Regards!
c.
