Vlans and Internet connection
Vlans and internet connection
So, I'm a little confused.
So i have 3 Vlans created.
Vlan 1 - Port 1 - 16
Vlan 50 Port 17 - 32
Vlan 100 Port 33 - 48
They each have their own dhcp server etc.
Which port should i connect my comcast cable to.  Should I have configured 1 port not to be apart of any vlan and connect it there.  Please advise.  Not sure where to go from here
See configuration below.
Switch#show config
Using 4362 out of 524288 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750g-48ts
system mtu routing 1500
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp pool vlan50
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
ip dhcp pool vlan100
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
switchport access vlan 100
switchport mode access
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
switchport access vlan 50
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 192.168.1.254 255.255.255.0
interface Vlan50
ip address 192.168.50.1 255.255.255.0
interface Vlan100
ip address 192.168.100.1 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
8 Replies 8
what Comcast device do you have ? Which switch do you have (which model, e.g. 2960) ?
Cisco 3750G and for Comcast it's the
Model:DPC3941T
Vendor:Cisco
you have a DOCSIS modem which I don't think you can configure to do address translation for more than the default network (10.x.x.x).
Your 3750G cannot do address translation, so it doesn't matter which port you connect the modem to. Only ports in the default VLAN 1 will be able to access the Internet (as these are getting IP addresses in the 10.x.x.x range)...
ok
So my computes that are connect to vlan 50 and vlan 100 will not be able to go online
Hello
Only high switching platforms supports NAT ( 6500+) so to provide NAT for you local subnet you'll need to put a router in between your Comcast and the 3750.
Kind Regards
Paul
Instead of a router can I use a ASA 5510 firewall
I just don't understand why my computers in vlan 50 and vlan 100 will not be able to go online.
For any edge device to access the internet the private address will need to be translated to a public 'routable' address. This is accomplished via NAT (Network Address Translation). You will need a device that is capable of NAT and routing. Think back to CCENT and CCNA studies, all traffic that traverses one subnet to another (Layer 3) needs to be routed. If you are also wanting to have multiple devices accessing the internet (sharing one public IP) you must NAT this traffic (overload).
N
