3650 switch crash error
baselzind
Level 7
Level 7
please can someone help me. I moved the switch to a new location then when I booted it up it crashed then afterward it booted normally and showed this below error? how do I prevent this from happening again?
Uptime for this control processor is 30 minutes
System returned to ROM by Critical process fed fault on fp_0_0 (rc=139)
System image file is "flash:packages.conf"
Last reload reason: Critical process fed fault on fp_0_0 (rc=139)
7 Replies 7
 Which version does this switch have?  This can easily be a Bug. Take a look here:
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvu35094
Im using Version 16.12.5 , there is no workaround for the bug
balaji.bandi
what is the version of code running, there may be bugs around ...
BB
Leo Laohoo
What firmware is the switch running on?
It could either be CSCvu84365 or CSCvu35094.
my Version 16.12.5
Mark Elsen
 - You may . for instance,  connect (SSH)  to the device with : https://cway.cisco.com/cli/ , on the right you can then use the Crashinfo Analyzer and on the left you can also use System Diagnostics.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
