3650 vs 3650G
linda.blaser1
What is the difference between the 3650 and 3650G mode switches?  Thanks.
8 Replies 8
jhager001
Since I can't find any documentation for a 3650G specifically, i'm going to say its not much different than what the 3650 series provides, maybe minor hardware differences. See reference.
http://www.cisco.com/c/en/us/products/switches/catalyst-3650-series-switches/models-comparison.html
Thank you.  I'm thinking the difference is the "G" model has all 48 (or 24) ports that go 10/100/1000 and the non- G model has all 10/100 ports except for the 4 GBIC ports, but I'm not certain.
IF you are referring to the 3560 model, then yes you are correct on the port speeds.
   Cisco Catalyst 3560-24PS: 24 Ethernet 10/100 ports with PoE and 2 SFP-based Gigabit Ethernet ports; 1 RU
   Cisco Catalyst 3560-48PS: 48 Ethernet 10/100 ports with PoE and 4 SFP-based Gigabit Ethernet ports; 1RU
   Cisco Catalyst 3560G-24TS: 24 Ethernet 10/100/1000 ports and 4 SFP-based Gigabit Ethernet ports; 1RU
   Cisco Catalyst 3560G-48TS: 48 Ethernet 10/100/1000 ports and 4 SFP-based Gigabit Ethernet ports; 1RU
   Cisco Catalyst 3560G-24PS: 24 Ethernet 10/100/1000 ports with PoE and 4 SFP-based Gigabit Ethernet ports; 1RU
   Cisco Catalyst 3560G-48PS: 48 Ethernet 10/100/1000 ports with PoE and 4 SFP-based Gigabit Ethernet ports; 1RU
Please rate helpful posts.
Thank you!
Yup, "G" for gig copper ports.
Leo Laohoo
There is NO SUCH THING as a "3650G".
Sorry, I must be dyslexic today...I should have type 3560 vs 3560G.
The main difference is just the amount of GigabitEthernet ports and SFP ports.
I haven't played with 3560/3560G for some time but I believe the flash size is also a difference (16 mb vs 32 mb).  May not sound much but the "G" can load IOS versions 12.2(58)SE  & 15.X but the non-"G" will only load IOS version up to 12.2(55)SE.
I believe the buffer size is the same.
