3650 vs 3850
ejdrijin1
I am in the process of buying some switches. I am comparing both 3650 and 3850 and I found the 2 below comparisons:
WIRELESS ACCESS POINTS per switching entity (Switch or Stack)  25 vs 50
WIRELESS CLIENTS per switching entity (Switch or Stack) 1000 x 2000
What does the above options mean?
Thanks.
brselzer
The 3850s support converged wireless. Meaning the 3850 can act as a wireless controller.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-1/converged_access_deployement_guide/m_conAccess_deploy_guide/converged_access_solution_overview.html
This restrictions would only apply if you were running the 3850 as a wireless controller and would be the number of APs and wireless clients you could have.
-Bradley Selzer
CCIE# 60833
Julio E. Moisa
It means a standalone switch will support until 25 access points, an access point could support between 25 and 40 concurrents clients. Now with a stack of switches you can support a max of 50 access points.
The maximum wireless cilents supported per switch or stack, a standalone switch could support max: 1000 (25 access points).
It also can depend on the model of the access point. Imagine an access point could support 35 concurrent clients so we could have on a switch: 35x25 = 875 clients passing through that switch.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
