IP Base vs IP Services
ejdrijin1
Level 3
Level 3
Can someone give me a quick review of what is EIGRP stub, OSPF for routed access and EIGRP stub routing? How do they differ from the EIGRP and OSPF in the IP Service switches?
Mark Malone
so with ospf routed you can only have around 200 learned routes
ipservices are not limited to 200 and can have thousands of ospf routes
eigrp stub is a stripped down version of full eigrp , cant be used as transit routers, the stub routers do not get queried for route info , they can advertise there connected routes and recieve summary routes , really for hub and spoke remote site routers with no other eigrp routers behind them
more info
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_eigrp/configuration/15-mt/ire-15-mt-book/ire-eigrp-stub-rtg.html
