3660 Question
dj214
Hello All:
I've looked through Cisco doc on this router and according to what I've read, this router will support a NM-1FE and not a NM-2FE. That doesn't sound right, can't see why. Does anyone know from experience if it does? Would rather pay the extra $$ and get the extra port.
Latest IOS. Thanks in advance
Edison Ortiz
Edison Ortiz
3660 supports up to 6 NM-2FE2W, please refer to this documentation:
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet09186a00801aa71c.html
HTH,
__
Edison.
Leo Laohoo
If you are willing to pay, then why not upgrade to a 2850 or 3845?
You have the options to use the following routed ports:
HWIC-1FE;
HWIC-2FE;
HWIC-GE-SFP; or
NME-16ESW
