3750 ARP Problem
infosateng
Level 3
Level 3
Hello Experts
I have 3 stacked 3750 Switches (WS-C3750-48TS, IOS c3750-ipservicesk9-mz.122-53.SE1) and I've started getting alerts that some of the connected servers are down, and a short time later that they are Up.  The alerts I get are not for all the servers, just ones on a partitular VLAN and not all the servers on this VLAN.  I think its an ARP problem as if I get alerts for 8 servers in a day and then I do a continuous ping to the these servers, I don't get any alerts any more, and the alerts move to different servers on the same VLAN.  I set the arp timeout on the VLAN interface to 1, but this didn't fix the problem.  Any idea how I can fix this.
Richard Burts
Setting the arp timeout to 1 is probably too short. Frequently on a switch like the 3750 people may set the arp timout to 300 seconds so that it agrees with the timeout for the entries in the mac address table.
Rick
Rick
Hi Rick
Thanks for the advise, but after changing the timeout to 300, I still have the same problem.
Without additional information I do not know what else to suggest. Do I understand correctly that the problems are happening on a particular vlan and not on others? If so then perhaps we can find out what is different about that vlan. Perhaps you could post the config of the switch with an indication about which vlan is experiencing the problems.
Rick
Rick
Hi Rick
I am having problems to VLAN 92.  The config  below
switch 1 provision ws-c3750-48ts
switch 2 provision ws-c3750-48ts
switch 3 provision ws-c3750-48ts
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
no ip source-route
ip routing
ip multicast-routing distributed
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
ip tcp synwait-time 10
interface Port-channel1
description Network 1 Path Redundancy
switchport access vlan 444
switchport mode access
speed 100
duplex full
interface Port-channel2
description Switch 2 Redundancy
switchport access vlan 92
speed 100
duplex full
interface Port-channel3
description Switch 3 Redundancy
speed 100
duplex full
interface Port-channel4
description Switch 4 Redundancy
speed 100
duplex full
interface Port-channel5
description Switch 5 Redundancy
speed 100
duplex full
interface FastEthernet1/0/1
interface FastEthernet1/0/2
description Connection to Management VLAN
switchport access vlan 10
speed 100
duplex full
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
switchport access vlan 82
speed 100
duplex full
interface FastEthernet1/0/6
speed 100
duplex full
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
description Server VLAN 82
speed 100
duplex full
spanning-tree portfast
interface FastEthernet1/0/11
speed 100
duplex full
interface FastEthernet1/0/12
speed 100
duplex full
interface FastEthernet1/0/13
speed 100
duplex full
interface FastEthernet1/0/14
speed 100
duplex full
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
speed 100
duplex full
interface FastEthernet1/0/18
speed 100
duplex full
interface FastEthernet1/0/19
speed 100
duplex full
interface FastEthernet1/0/20
interface FastEthernet1/0/21
speed 100
duplex full
interface FastEthernet1/0/22
interface FastEthernet1/0/23
speed 100
duplex full
interface FastEthernet1/0/24
speed 100
duplex full
interface FastEthernet1/0/25
speed 100
duplex full
interface FastEthernet1/0/26
interface FastEthernet1/0/27
interface FastEthernet1/0/28
interface FastEthernet1/0/29
interface FastEthernet1/0/30
interface FastEthernet1/0/31
description Server VLAN 92
speed 100
duplex full
interface FastEthernet1/0/32
speed 100
duplex full
interface FastEthernet1/0/33
speed 100
duplex full
interface FastEthernet1/0/34
interface FastEthernet1/0/35
speed 100
duplex full
interface FastEthernet1/0/36
interface FastEthernet1/0/37
speed 100
duplex full
interface FastEthernet1/0/38
speed 100
duplex full
interface FastEthernet1/0/39
speed 100
duplex full
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
description Connection Switch 2 Fe0/2
speed 100
duplex full
channel-group 2 mode on
interface FastEthernet1/0/43
description Connection to Switch 3 Fe0/2
speed 100
duplex full
channel-group 3 mode on
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface FastEthernet2/0/1
description Connection to Network 1
speed 100
duplex full
interface FastEthernet2/0/2
interface FastEthernet2/0/3
interface FastEthernet2/0/4
interface FastEthernet2/0/5
interface FastEthernet2/0/6
interface FastEthernet2/0/7
interface FastEthernet2/0/8
interface FastEthernet2/0/9
interface FastEthernet2/0/10
speed 100
duplex full
interface FastEthernet2/0/11
speed 100
duplex full
interface FastEthernet2/0/12
speed 100
duplex full
interface FastEthernet2/0/13
speed 100
duplex full
interface FastEthernet2/0/14
speed 100
duplex full
interface FastEthernet2/0/15
interface FastEthernet2/0/16
interface FastEthernet2/0/17
speed 100
duplex full
interface FastEthernet2/0/18
speed 100
duplex full
interface FastEthernet2/0/19
speed 100
duplex full
interface FastEthernet2/0/20
speed 100
duplex full
interface FastEthernet2/0/21
speed 100
duplex full
interface FastEthernet2/0/22
interface FastEthernet2/0/23
speed 100
duplex full
interface FastEthernet2/0/24
interface FastEthernet2/0/25
speed 100
duplex full
interface FastEthernet2/0/26
interface FastEthernet2/0/27
interface FastEthernet2/0/28
interface FastEthernet2/0/29
interface FastEthernet2/0/30
interface FastEthernet2/0/31
speed 100
duplex full
interface FastEthernet2/0/32
speed 100
duplex full
interface FastEthernet2/0/33
speed 100
duplex full
interface FastEthernet2/0/34
speed 100
duplex full
interface FastEthernet2/0/35
speed 100
duplex full
interface FastEthernet2/0/36
interface FastEthernet2/0/37
speed 100
duplex full
interface FastEthernet2/0/38
interface FastEthernet2/0/39
speed 100
duplex full
interface FastEthernet2/0/40
interface FastEthernet2/0/41
interface FastEthernet2/0/42
description Connection to Switch 2
speed 100
duplex full
interface FastEthernet2/0/43
speed 100
duplex full
interface FastEthernet2/0/44
description Connection Switch 4
speed 100
duplex full
channel-group 4 mode on
interface FastEthernet2/0/45
description Connection to Switch 5
speed 100
duplex full
channel-group 5 mode on
interface FastEthernet2/0/46
description Management VLAN
interface FastEthernet2/0/47
speed 100
duplex full
interface FastEthernet2/0/48
description FW 1
switchport access vlan 333
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface FastEthernet3/0/1
speed 100
duplex full
channel-group 1 mode on
interface FastEthernet3/0/2
no cdp enable
interface FastEthernet3/0/3
no cdp enable
interface FastEthernet3/0/4
no cdp enable
interface FastEthernet3/0/5
no cdp enable
interface FastEthernet3/0/6
no cdp enable
interface FastEthernet3/0/7
no cdp enable
interface FastEthernet3/0/8
no cdp enable
interface FastEthernet3/0/9
no cdp enable
interface FastEthernet3/0/10
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/11
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/12
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/13
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/14
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/15
no cdp enable
interface FastEthernet3/0/16
no cdp enable
interface FastEthernet3/0/17
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/18
no cdp enable
interface FastEthernet3/0/19
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/20
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/21
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/22
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/23
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/24
no cdp enable
interface FastEthernet3/0/25
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/26
no cdp enable
interface FastEthernet3/0/27
no cdp enable
interface FastEthernet3/0/28
no cdp enable
interface FastEthernet3/0/29
no cdp enable
interface FastEthernet3/0/30
no cdp enable
interface FastEthernet3/0/31
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/32
no cdp enable
interface FastEthernet3/0/33
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/34
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/35
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/36
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/37
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/38
no cdp enable
interface FastEthernet3/0/39
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/40
no cdp enable
interface FastEthernet3/0/41
no cdp enable
interface FastEthernet3/0/42
no cdp enable
interface FastEthernet3/0/43
no cdp enable
interface FastEthernet3/0/44
description Connection to Switch 4
speed 100
duplex full
interface FastEthernet3/0/45
speed 100
duplex full
interface FastEthernet3/0/46
interface FastEthernet3/0/47
speed 100
duplex full
no cdp enable
interface FastEthernet3/0/48
description FW 2
no cdp enable
interface GigabitEthernet3/0/1
no cdp enable
interface GigabitEthernet3/0/2
no cdp enable
interface GigabitEthernet3/0/3
no cdp enable
interface GigabitEthernet3/0/4
no cdp enable
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.0.10.12 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan82
ip address 10.2.12.1 255.255.255.0
ip pim dense-mode
ip igmp query-interval 125
no ip mroute-cache
interface Vlan92
ip address 10.2.20.1 255.255.255.0
arp timeout 300
interface Vlan444
ip address 10.8.8.1 255.255.255.252
interface Vlan333
description FW
ip address 10.8.2.249 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim dense-mode
no ip mroute-cache
router rip
version 2
passive-interface Vlan444
passive-interface Vlan333
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.8.2.250
ip route 10.0.5.0 255.255.255.0 10.0.10.1
ip route 10.10.4.0 255.255.254.0 10.0.10.1
ip route 10.254.202.2 255.255.255.255 10.8.8.2
ip route 10.254.200.0 255.255.255.240 10.8.8.2
