sg200 Lag Setup to Catalyst 3750
matty15206_2000
Hi All,
I am trying to work out how to setup a port channel between a SG200 and 3750 and am having problems.
What do I need to do on the SG200 I have added the port into the lag but the port will not come up.
If anyone knows what I am missing that would be great spent half a day messing arround with the web interface and I am unable to get the port to come up.
The Cisco 3750 is a standard port channel config which I have setup maytime before.
channel-group 1 mode active
channel- protocl lacp
Switchport mode trunk
Matt
Jan Rolny
Level 3
Level 3
Hi Matt,
somebody had simmilar problem. Check this link if it is not same problem.
https://supportforums.cisco.com/thread/2082766
Best Regards,
Jan
