3750 Backplane Speed - Is it fixed regardless of stack size?
GRANT3779
Hi All,
Just been watching the following QOS video from Cisco Live - https://www.youtube.com/watch?v=ooy9U4srPXA
He mentions the 3750 has a 64Gbps backplane (2 x 32Gbps dual counter rotating rings). It is then said that if a switch was added to the stack, the backplane would stay the same. Would the stack backplane not increase if another switch was added or is does the stack as a whole share one backplane of 64Gbs? It's at 1:00:20 in the video that this is all mentioned.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Much depends on whether the 3750 series in question has StackWise or StackWisePlus.  The former is "documented" as 32 Gbps, the latter as 64 Gbps.  But, besides the difference in ring bandwidths, the former uses the source device to take the frame off the ring that it placed on the ring while the latter, for unicast, uses the destination device to take the frame off the ring (Cisco calls this spacial reuse).  So, for the former, the ring bandwidth is shared with all stack members.  With the latter, bandwidth sharing depends on where the traffic flows are going.  Best case, for the latter, would be source and destinations are only on neighbors on the ring.  For such a case, each member to member ring adds 64 Gbps.  Worst case, would be multiple switch members needing to transit other switch members but (again for unicast) this is better than source stripping.
