3750 Config for IP Phone with PC connection
Tim Johnson
We have a remote location that has a Mitel 3300 VoIP solution. The company has always configured a separate dedicated port for phone and data.
We have a new location opening, again with the Mitel VoIP system, and I am testing having the 3750 ports configured such that the PC would connect to the Mitel IP Phone and then the IP Phone has the switch connection. What I have configured is as follows:
interface FastEthernet1/0/4
description // SHARED IP Phone with PC //
switchport access vlan 10
switchport mode access
switchport voice vlan 200
switchport priority extend trust
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust cos
auto qos voip trust
spanning-tree portfast
So, data vlan is 10, voice vlan is 200. I connected a pc to the IP phone and everything worked fine.
My question is in the port configuration. I did not put the srr-queue in the config, rather, the auto-qos did it's job and put it in the config, along with a bunch of mls qos configuration details.
So - to the questions
1) Is my port configuration correct? (yes, I know it works, but is there a better way that people have been doing this)
2) Do I need all the commands in the port configuration, just wondering if I'm doing two different things with the "mls qos trust" and the "auto qos VoIP trust"?
Thanks in advance.
Tim Johnson
bump
