3750-E with Cisco Enhanced PoE (20mW) for 1250 APs
Jason Aarons
Level 6
Level 6
How many Cisco Aironet 1250 APs running 3x2 at 20mW under Cisco Enhanced PoE are supported on 3750E-48PD? Does it change with 3750E-48PD-F? How about X4648+E blade from 6500?
Where can I find a power calculator for 3750E?
I once had a customer buy 48 Cisco 7970 phones to find the 3560 switch couldn't power them all. Trying to avoid a repeat of that scenario.
Mark Yeates
Level 7
Level 7
Jason,
Here is a link to the Cisco Power Calculator.
http://tools.cisco.com/cpc/launch.jsp
HTH,
Mark
The Power Calculator doesn't have a 20mW option for 1250 2x3 operation under Cisco Enhanced Power. I'm wondering if Cisco Enhanced Power might have other caveats.
Sorry, I didn't realize that the 20W option was not available on the power calculator. I found two helpful documents showing that enhanced PoE is available.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/QA_Enhanced_Power_over_Ethernet.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/White_Paper_C11-453743-00.html
You will need the following IOS versions:
3560-E/3750-E: 12.2(44)SE or later.
4500: 12.2(44)SG or later, and an E series linecard.
6500: 12.2(33)SXH2 or later, all PoE line cards.
HTH,
Mark
