05-20-2009 11:03 AM - edited 03-06-2019 05:50 AM
We are having issues with our Equalogic SAN reporting Disk Latency Issues. Equalogic points to the switches which show no signs so far of any latency issue or drops. These are 3750E series switches with no routing, just switching and all data is going through one single switch so no transfers across a network.
Any ideas would be really appreciated.
05-20-2009 11:06 AM
Check your input/output interface buffers for drops and or overruns.
Frank
05-20-2009 11:07 AM
Frank,
I think I have but what is the best command to use to do that? I've done the show switch diag and the show tech
any better command?
05-20-2009 11:18 AM
show interface command
Example:
SWITCH1#sh int t1/1
TenGigabitEthernet1/1 is up, line protocol is up (connected)
Hardware is C6k 10000Mb 802.3, address is 0022.0d04.a800 (bia 0022.0d04.a800)
Description: SWITCH3 T5/4
Internet address is 172.25.2.4/31
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, media type is 10Gbase-LX4
input flow-control is on, output flow-control is off
Last input 00:00:03, output 00:00:00, output hang never
Last clearing of "show interface" counters 23:56:09
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L2 Switched: ucast: 92 pkt, 7291 bytes - mcast: 18639 pkt, 2199754 bytes
L3 in Switched: ucast: 17256985 pkt, 24556456241 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 7795285 pkt, 499308860 bytes mcast: 0 pkt, 0 bytes
17284423 packets input, 24560400239 bytes, 0 no buffer
Received 27270 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
7822728 packets output, 503256442 bytes, 0 underruns
