Embedded Packet Capture
fsebera
Level 9
Level 9
I want to capture specific data traffic flowing --through-- my switch (6509E, Sup720-10G) and found the IOS Embedded Packet Capture utility.
Anyone have experience using this tool?
I thought best to limit my selected traffic via an Extended ACL.
Tks
Frank
rais
Level 11
Level 11
Ethanalyzer is available on Nexus 7000 Series switches. It's a wireshark application.
If it's supported on 6509 you should be able to run this command.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_0/nx-os/system_management/command/reference/sm_cmd_e.html
Thanks.
NADA.
