3750 G - Stack Question
dj214
Level 3
Level 3
Hello All:
I had 2 3750's stacked and had to split them. I disconnected them and issued the np provision command for #2. All is well except the switch ports on the 2nd switch are still labeled as 2/0/0x instead of 1/0/1x  etc. How can I revert that switch back to prestack time.?
DJ
sachinraja
Level 11
Level 11
Hi DJ
Can you give "show switch" on the second switch  and see the stack number on it ?
try the command " switch member-number renumber new-member-no"
specify the current stack number (which i presume is 2), and then the new stack number (which is 1 ?)
then do a reset to the stack member (reload) and see if it comes back..
verify by giving a show switch again..
Hope this helps.. all the best..
Raj
