3750 IP Routing
dtom
We currently have  3725 router with an ip address of 172.16.1.1 and a 3750 switch with an ip address of 172.16.1.9.  Our goal here is to use the 3750 as a router and remove the 3725.  Here is a partial current config:
3725
interface FastEthernet0/0
description S/N FTX1026A5XW
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description Network
encapsulation dot1Q 1 native
ip address 172.16.2.1 255.255.255.0 secondary
ip address 172.16.1.1 255.255.255.0
ip helper-address 10.223.250.60
interface FastEthernet0/0.3
description Student Vlan
encapsulation dot1Q 3
ip address 10.2.3.1 255.255.255.0
router eigrp 64
network 10.0.0.0
network 172.26.0.0
no auto-summary
3750
interface GigabitEthernet1/0/12
description UL from Router
switchport mode trunk
spanning-tree portfast trunk
interface Vlan1
ip address 172.16.1.9 255.255.255.0
ip default-gateway 172.16.1.1
What we want to do is some initial prep work on the 3750 (prior to removing the 3725).  Here are the statments that we are thinking about adding to the current 3750 config:
3750
ip routing
router eigrp 64
network 10.0.0.0
network 172.16.0.0
no auto-summary
By adding the above to the current 3750 config, will this cause any issues (prior to removing the 3725)?  Do we need to remove the ip default-gateway statement?  Also, we will change the the address on the 3750 after we remove the 3725 to 172.16.1.1 as well as add Vlan3.
InayathUlla Sharieff
Its always recommended to do these type of changes during the Maintainence Window. So that you can test everything within the span of time.
Inayath
