3750 Local SPAN problem.
cityloveyou
Community Member
Hello, everyone:
I am encount a problem when I do a Local SPAN on an 3750 Switch.
My 3750 runs on  version 12.2(25)SEB4 IOS .
I need to SPAN two port's traffic to one port to work with Websense.
The port  needs to be able to monitor and send traffic.  Here is what we used:
monitor session 1 source interface Gi1/0/23 - 24
monitor session 1 destination interface Gi1/0/21 encapsulation replicate ingress dot1q vlan 1
I have SVI configured, and the PC connect to Gi1/0/21 has the IP address of VLAN1 ,  my problem is , from the PC , I can ping to any other hosts in VLAN1, BUT I can not ping to the VLAN1 SVI interface , namely , I can not ping to the gateway of VLAN1 , so , I can not make the PC to communicate with the PCs in other VLANs.
The only way to send packets to other vlans ,vlan 10 for example , I need to let PC to send the packet with a VLAN tag 10 in its packet.
It there a way to make PC connect to Gi1/0/21 to communicate with PCs in other VLANs by SVI forwarding?
Any suggestion is appreciated.
Thank you all
7 Replies 7
milan.kulik
Level 11
Level 11
how does the interface Gi1/0/21 configuration look like?
Have you tried your PC sending untagged packets together with
monitor session 1 destination interface Gi1/0/21 encapsulation replicate ingress untagged vlan 1
command?
HTH,
Milan
I 've tried this configuration , but it seems no effect..
thank you  for you advice~
Vivek V
I would be helpful if you could add the entire config here, ie .. config on svi , config on interface.
/ Vivek
Hi , Vivek,
Here is my full "sh run" output .
Building configuration...
Current configuration : 2322 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname XXXX
enable secret 5 $1$banu$36zuNWgvOv9vvH2raeK5X/
no aaa new-model
switch 1 provision ws-c3750g-24ps
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/3
switchport access vlan 20
interface GigabitEthernet1/0/4
(No configuration of these Ports, output omitted.....)
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
switchport access vlan 100
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 10.10.1.1 255.255.255.0
interface Vlan10
ip address 10.10.10.1 255.255.255.0
interface Vlan20
ip address 10.10.20.1 255.255.255.0
interface Vlan100
ip address 10.10.100.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.100.253
ip http server
control-plane
line con 0
line vty 0 4
password firewall
login
line vty 5 15
password firewall
login
end
IS there something I did wrong?
Thank you very much
BTW, I noticed that , when PC ping to VLAN1  SVI 10.10.1.1  ,  an incompleted ARP entry been observed on PC, by capture packets ,  The ARP request for IP 10.10.1.1 got NO ARP response. BUT, by launch "debug ip arp" on the 3750 , I really see the ARP response .
Seems like that , the ARP response been constructed, by didn't sent out Gi1/0/21
Thank you Again~
cityloveyou
Community Member
Is there anybody can help me ?
Any sugggestion or advice is appreciated.
make g1/0/21 an access port, not a trunk port.  You should also not be putting devices in Vlan1.  Put the websense server in another vlan (ie. vlan 5 - assigned for monitoring) and update your monitor line accordingly (ie. encapsulation replicate ingress  dot1q vlan 5) (if youre creating a new vlan, make sure to create the svi if you want to route off of it).
Hi , Joneswill:
I need to see vlan tags on the the port gi1/0/21 , so this is why I set gi1/0/21 to trunk mode.
Is there another workaround on my particular requirement ?
Thank you
