3750 mls qos question
O_H
I have core switch connected to uplink Cisco router on 1/0/48. Port 1/0/1 on the switch is connected to a server.
Now here is the configs for both ports for comparision:
interface GigabitEthernet1/0/1
description Server
switchport trunk allowed vlan 10,70,200,115,192,193
switchport mode trunk
spanning-tree portfast edge trunk
interface GigabitEthernet1/0/48
description uplink ROUTER
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust
end
CORE#show mls qos interface gigabitEthernet 1/0/1 queueing
Egress Priority Queue : disabled
Shaped queue weights (absolute) : 25 0 0 0
Shared queue weights : 25 25 25 25
The port bandwidth limit : 100 (Operational Bandwidth:100.0)
The port is mapped to qset : 1
CORE#show mls qos interface gigabitEthernet 1/0/48 queueing
Egress Priority Queue : enabled
Shared queue weights : 1 30 35 5
The port is mapped to qset : 2
Now, queuing is applied on 1//0/48 but not on 1/0/1.
what //The port bandwidth limit : 100 (Operational Bandwidth:100.0)// means? Does it mean that the interface BW can't go higher than 100? why?
Also, how to disable any queuing on the 1/0/48 to grant full 1G bandwidth?
pieterh
bandwith is "limited" to 100% (percent ) not bps!
pieterh
Joseph W. Doherty
BTW, if I'm reading your posted information correctly, the first queue might also be shaped, i.e. capped.
